ToH3.3
    ToH3.3
    Pe DVB la upload,pacat ca aici nu putem posta nimic...
    Humy
    Ultimul soft il gasiti si aici:
    http://65.75.149.180/~satellit/index...electcat&cat=3
    Cu Key.bin actual deschide in plus pe linga Conax si ceva din Cyfra (Cartoon si ceva TVN)
    Salut.
    Take life the way you go!
    prays
      Humy
      Xamuh PMC table ToH3.3 HoT2.0/2.0.1
      You can do the following selections with the " CAID Preselect "
      [CARD+EMU]>>>>>>[For Emulator DEFAULT use + ******(2) card (fast zap)
      [CARD+EMU+S]>>>>[For Emulator + Card Sharing (Premiere + Irdeto2)
      [CARD+EMU+S]>>>>[Slow Zap
      [CARD+S+EMU]>>>>[For Emulator + Card Sharing (Premiere + Cryptoworks)
      [CARD+S+EMU]>>>>[Also support CAM with Conax card in EMU mode (slow zap)
      [CAS1]>>>>>>>>>>[For Emulatorek/Wallbanger auto switch
      [CAS2]>>>>>>>>>>[For Nagra Aladin test
      [CAS3]>>>>>>>>>>[For people with SkyCrypt and Conax supported CAM's
      [CAS4]>>>>>>>>>>[For people with Nagra supported CAM's or ****** 2 test
      [CAS5]>>>>>>>>>>[For Cryptoworks test
      [CAS6]>>>>>>>>>>[For SHL test
      Fara comentarii.salut.
      prays
        Servus,
        A reusit cineva sa folosesaca Card Sharing-ul ?! Si daca da : cum ?!
        Eu unul nu prea reusesc sa il conectez ....
        Multumesc anticipat pentru raspunsuri .
        Bafta !
        BAFTA TUTUROR !
        S_H
          Humax utile
          Aplicatii utile ptr Humax si ......... nu numai
          _______________________
          HumaxSmartSuite 1.0
          HumaxSmartSuite is a group of applications dedicated to the Humax world,
          better to say the Humax OAK world.
          At the moment HumaxSmartSuite is made up of HSS (Application Center), HDFSmart (tool for the hdf firmware analisys) and
          settings editor HNFSmart (xOak evolution).
          Each application can be installed in independent way and it is not indispensable to the others
          for the corrected operation; it's easy to understand that HSS will be useless if you do not install
          the others.
          Tools
          HSS.exe - Application Center
          HDFSmart
          With HDFSmart it is possible to open whichever HDF files (OAK related) and to carry out the
          analysis, verify data type (firmware, PMCT, Macro, Settings, etc.)
          HNFSmart
          HNFSmart replaces xOak 1.17
          http://www.humaxsmartsuite.com/
          Humax Smart Suite
          http://www.humaxsmartsuite.com/send...ename=HSS10.zip
          HDFSmart
          http://hdf.humaxsmartsuite.com/sendz...HdfSmart11.zip
          HNFSmart
          http://hnf.humaxsmartsuite.com/sendz...HnfSmart20.zip
          prays
