Triple-Dragon box! (Dreambox-Killer???) EUR 355,00
    Triple-Dragon (Beta-Box)
    http://www.mnc-trading.de/
    Main processing components
    CPU IBM PowerPC 405
    RAM 64 MB for operation system and applications
    16 MB for graphical subsystem (framebuffer)
    ROM 8 MB Flash EEPROM
    Tuner
    Input 1x F-Connector
    Output 1x F-Connector
    Input-/Output-Impedance 75 Ohm
    IF-frequency range 950 - 2150 MHz
    IF-signal level -65 to -25 dBm
    Channel Bandwith/td> ariabel 10 - 30 MHz in steps of 2,5 MHz
    tunig system PLL-Synthesizer
    minimum tuning step size 125 KHz
    PLL-Locktime typ. 20 ms / max. 50 ms
    LNB-Supply voltage 14 / 18 V
    max. LNB-Supply current 400 mA
    LNB Control-signal 22 KHz / 0,6 Vpp
    Demodulator
    Modulationtypes QPSK (DVB-Systems), BPSK* (DSS-Systems)
    Symbolrates 2 - 45 MBaud
    FEC DVB: 1/2, 2/3, 3/4, 5/6, 7/8
    DSS: 1/2, 2/3, 3/4, 5/6, 6/7
    MPEG Decoder
    Video MPEG-2 acording ISO/IEC 13818-2 [email protected]
    MPEG-1 acording ISO/IEC 11172-2
    Audio MPEG-1 / MPEG-2 (Layer I and II) and MPEG-1 Layer III (MP3)
    Audio-/Video In-/Outputs
    combined In-/Outputs 2x Euro-AV (SCART), therefrom:
    - 1x TV-Out with RGB/YUV (optional with Sync on green),
    Composite Video (CVBS) and stereo Audio
    - 1x Aux-In for RGB, Composite Video (CVBS) and stereo Audio
    1x RF-Out (UHF-Modulator Software-controlable)
    Video In-/Outputs 1x RCA (Cinch) Composite Video Out (CVBS)
    1x RCA (Cinch) Composite Video In (CVBS)
    1x Mini-DIN (Hosiden) S-Video Out
    Audio In-/Outputs 1x RCA (2x Cinch) stereo Audio Out
    1x RCA (2x Cinch) stereo Audio In
    1x RCA (Cinch) electrical S/PDIF digital Audio Out
    1x Toslink optical S/PDIF digital Audio Out
    Data In-/Outputs
    Netzwork 1x RJ45 100 Mbit/s Full Duplex
    USB 1x Typ A with optional cable adapter
    Systembus 1x 50-pin Mini-Sub-D Connector for DVR-3000
    IDE 1x 40-pin ribbon cable connector for additional harddisk
    Pay-TV
    integrated 2x Cardreader licensed for Conax. Other systems on demand and neccesary licensing
    Common Interface 1x Slot for CI-Modules
    User interface
    Global OnScreen Display OSD an TV and LC-Display
    OSD-/LCD-Languages English, German, Greek, Italian, Norwegian, Polish, Russian, Slovak und Turkish
    Channel management
    storable channels depending on the channel name length between 6000 and 8000. With reconfiguration of the memory
    management even more possible
    Favorites unlimmited, free editable
    Channels search per satellit automatic all configured satellites, choise of configured satellites orr one satellite.
    User choice storing all Channels or only free to air channels
    Channel search per transponder yes, by input of satellite- and transponder relevant data
    Antenna control
    Mini-DiSEqC yes
    DiSEqC 1.0 yes
    DiSEqC 1.1 yes (software not yet finished)
    DiSEqC 1.2 (Rotor) yes
    USALS (Rotor) yes (not yet certified)
    12V Relais yes, also in combination with DiSEqC/USALS
    LNB-Power for polarity control or switched off fur special purpose configurations
    C-Band reception yes
    Video outputs
    RGB yes via SCART-connector, no YUV if RGB is selected
    YUV yes via SCART-connector, no RGB if YUV is selected
    S-Video yes, dedicated output Mini-DIN-connector
    Composite Video (CVBS) yes, dedicated output Cinch-connector and SCART-connector
    HF-modulated yes, UHF channel 21 to 69, controllable by software
    Videoformats
    50 Hz Systems PAL-B/G/H, PAL-N, PAL-I, PAL-K, SECAM-L/D/K, SECAM-H
    60 Hz Systems NTSC-M, PAL-M
    Picture aspect ratio
    4:3 yes, in this case 16:9 as letterbox or zoomed
    16:9 yes, in this case 4:3 with vertical borders
    automatic 4:3 / 16:9 yes, signalling to the TV via SCART-switching voltage
    Audio-Options
    Dolby Digital AC3 yes, if available to the channel. Bitstream out to S/PDIF-outputs
    DTS yes, if available to the channel. Bitstream out to S/PDIF-outputs
    Electronic Program Guide EPG
    Short Event Info yes, for current and next transmission while switching to the channel or after request
    Long Event Info yes, for all available transmissions from the channel by request
    Teletext
    Software-Decoder yes, acording to Level 1.5 incl. Enhancements Cache 4000 pages
    Character sets Latin including all national subsets, kyrillic, greek
    Navigation systems TOP, FLOF and Cursor
    Subtitles yes, also without knowledge about the page number via OSD
    Software Updates
    Medium via Netzwork from a PC
    from Windows-PC free Tool or every TFTP-Server-Software
    from Linux-PC Linux-integrated TFTP-Server
    Programming interface
    Plugins loadable from USB-Memory (USB-Sticks, ...)
    Shipped parts
    - Set-Top-Box
    - Power cord
    - Remote control
    - printed user manual
    - mounting-kit for harddisk, preinstalled with cables
    EUR 355,00
    http://www.mnc-trading.de/pd-200155294.htm?categoryId=0
    Dreambox 900 4K / Nvidea Shield StreamBox
    Gata
    A aparut la vinzare? Se poate cumpara de oricine e interesat sau numai de cei alesi pentru testare?
      @claudiu
      Vezi ce scrie aici:
      Herzlich willkommen bei MNC Ltd. Deutschland-Trading
      415 Triple-Dragon in 1 Woche verkauft !
      Die erste Lieferung des Triple-Dragon trifft am 28. Juli ein und kann bereits Anfang August bei Euch sein. Die ersten 500 Geräte haben wir für unsere Betatester reserviert. Aufgrund der hohen Nachfrage zählt die Reihenfolge des Zahlungseingangs - also viel Glück und viel Spaß mit dem Triple-Dragon. Der Preis gilt zzgl. Versandkosten.
      Hinweis: Wir haben bisher ausschließlich Detailfotos in schwarz - die Geräte werden aber in der gewünschten Farbe geliefert.
        Scuze
        Imi pare tare rau dar sint paralel cu limba germana.Ti-as multumi tare mult daca mi-ai traduce pe scurt despre ce este vorba in anunt.
          @claudiu
          415 buc. de Triple-Dragon vandute in 1 sapt.! bla..bla...
          Mai trebuie asteptat!
          Sa vedem ce iese!
            Suport
            Oare ce suport o sa aiba,si ce tuner?
            Hmmm deja ma gindesc sa schimb dreamul!
            350 kg de scule!
              tuner
              S-a mai discutat; tunerul este sharp,suportul soft-trupa lui uli herrman
                Circotas
                Se poate memora TV Sport
