vPlug
This is a sticky topic.
    vPlug
    A aparut vPlug 0.9 :
    http://dvb-upload.com/index.php?acti...load&pid=55485
    "History
    15.06.2006
    V 0.9.0
    -Bug Fix: fixed N2 dcw's parsing (moderate intermittent freezes). (Thnx to Daex)"
    Thanks Vahid!
    A aparut vPlug 0.9.1
    http://dvb-upload.com/index.php?acti...load&pid=56553
    "23.06.2006
    V 0.9.1
    -New : Cryptoworks emulation has been Added. (Thnx to st20tp2)
    SoftCam.key format: (similar to camd3.keys)
    ;W -> Cryptoworks ; 0DnnYY -> 0Dnn=CAID, YY=Provider id
    W 0DnnYY 00 xxxxx ; 32 characters = ECM Key index 00
    W 0DnnYY 01 xxxxx ; 32 characters = ECM Key index 01
    W 0DnnYY 06 xxxxx ; 12 characters = CardSystem Key
    W 0DnnYY 80 xxxxx ; 32 characters = EMM-G Key index 00
    W 0DnnYY 81 xxxxx ; 32 characters = EMM-G Key index 01
    W 0DnnYY B0 xxxxx ; 128 characters = RSA Key
    -Update : v_get_key.ini file has been updated. (Thnx to Zakari)
    -Bug Fix : Writing Via-1's found key to softcam.key file.
    A quick how-to: (Via-1 AU without internet connection)
    a) you should have au.bin file.
    b) tune to one of the SRG's channels.
    c) open vPlug's monitor and select emm tab.
    d) click at find pid's.
    e) select emm-pid of 009400 from the dropdown list.
    f) click at start button and wait. (max. 5 minutes)
    or
    c,d,e,f) -> edit v_emm.ini file like this:
    [009400]
    emm_pid_hex=0259
    AutoTerminateOnKeyFind=1
    AutoStartOnChannelChange=1
    -Update : "Reread SoftCam.Key" menu option has been removed. Now its changes are being watched."
    Thanks Vahid!
      A aparut vPlug 0.9.2
      http://dvb-upload.com/index.php?acti...load&pid=56769
      "24.06.2006
      V 0.9.2
      -Bug fix : Fixed Crash on exit.
      -Update : v_get_key.ini file has been updated."
        Nu mai da eroare pe ProgDVB
        Confirm ca acum nu mai apare mesajul de eroare la inchiderea ProgDVB
          vPlug 0.93
          http://dvb-upload.com/index.php?acti...load&pid=58280
          "07.07.2006
          V 0.9.3
          -New : Preferences editor.
          -Update : Some fixes for AutoAESfromWeb.
          -Bug fix : Error in calculating hash of Viasat3 (Viaccess PC-2.3) has been fixed.
          -Bug fix : ECM parsing of Cryptoworks has been fixed."
          vPlug 0.94
          http://dvb-upload.com/index.php?acti...load&pid=58346
          "07.07.2006
          V 0.9.4
          -New : Offline Debugger.
          -Bug fix : Fixed broken N2 ECM handling.
          -Bug fix : Adding non-repetitive new found AES key to the end of Softcam.Key file."
            mie nu imi merge linkul asta?
            e problema la mine sau...e generala?
              Am testat si merge.
              Eventual incearca asa http://dvb-upload.com/index si cauti in lista.
                vplug 0.9.4
                http://gyik.ws/download.php?name=vPlug0.9.4.zip
                Teacher
                  Nu mai stie vPlug sa gaseasca cheile? Pai sa mai caute si in alta parte!
                  De la tatal lui, adica de la Vahid, citire:
                  Add it to top of the v_get_key.ini file:
                  Code:
                  [rubydesign.info]
                  site_url=http://www.rubydesign.info/aes/linuxkeys.php
                  regular_exp_pattern_to_find_key=(?s):\d{2}\w+?:\w+?)\s
                  key_part1_exp=
                  key_part2_exp=
                  Copiati in partea superioara a fisierului " v_get_key.ini " (care se gaseste in folderul cu vPlug.dll), textul urmator:
                  [rubydesign.info]
                  key_part1_exp=
                  key_part2_exp=
                  [http://www.rubydesign.info/aes/]
                  key_part1_exp=(?s)clef\sPri\s:\s07\s.+?)
                  key_part2_exp=(?s)clef\sSec\s:\s07\s.+?)
                    confirm ca e OK pe TPS
                    confirm ca e OK . Am pus soft Softcam.Keys_July12th All Ok.zip de la http://dvb-upload.com/index.php?acti...load&pid=59007
                      vPlug0.9.5
                      http://www.********.ro/upload/vPlug0.9.5.zip
                      "15.07.2006
                      V 0.9.5
                      -Update : Freezes during the AES key changes have been fixed. (It needs a good server for sure)
                      -Update : Automatically disabling use_TTTrick when it is not supported."
                      Thanks Vahid!
                        ciudat
                        cu versiunea veche gasea keyle da cu asta nu vrea
                          Daca pui in v_get_key.ini ce a scris SLAMAN merge! Numai ca parca intepenirile sunt mai lungi!?
                            Cheile AES pana in data de 21.07 ora 2:34
                            Ora este ora GMT+2.
                            Schimbarea de azi de la 11:48 am testat-o si a fost adevarata!
                            http://sat-key.info/phpbb/viewtopic.php?t=62542
                            16-07-2006 19:21:00
                            key: FA 0C 3E 69 CF 67 2E CE 81 E8 25 63 C4 06 D5 C1
                            16-07-2006 19:35:00
                            key: 3B 94 11 EE 48 61 02 7E E5 EE CA D8 FC F7 6E F2
                            16-07-2006 19:49:00
                            key: E0 0B 7B 5D 01 CA DA C4 25 D7 46 E7 55 EF CD 4A
                            16-07-2006 20:10:00
                            key: 21 46 5B 8B 2E 93 48 A0 BF 05 9E F1 45 0D BD B0
                            16-07-2006 20:24:00
                            key: 49 2D F9 AC 23 DC 93 B8 00 60 9C 58 52 B4 3C 39
                            16-07-2006 20:32:00
                            key: CA 49 5D 2C 1D AC 80 A7 1A CB 95 9A 97 22 FA B0
                            16-07-2006 20:48:00
                            key: 3D B5 E8 A9 4A FF FF 73 8E 6F C7 5A E6 9D 64 CC
                            16-07-2006 21:09:00
                            key: DA C0 B0 26 D1 EF EF BE EB 68 61 2F EF B5 51 3D
                            16-07-2006 21:21:00
                            key: 4F 92 4D DB C4 D2 5C 90 A7 AA B6 E9 1B 0B 5D 1E
                            16-07-2006 21:34:00
                            key: 31 9D 19 B4 67 16 A8 8B DC 0E 72 67 A7 41 75 5E
                            16-07-2006 21:48:00
                            key: E0 CD 4F A0 7C 4D 4D 46 60 4A 3D 90 2F FB 91 F4
                            16-07-2006 22:09:00
                            key: D3 B0 71 A0 51 2D B2 1A 7A 51 28 F6 CA EC 91 08
                            16-07-2006 22:22:00
                            key: 7D 79 F2 85 93 04 37 B4 2F E8 BA 04 A3 48 7B 86
                            16-07-2006 22:38:00
                            16-07-2006 22:55:00
                            key: 1D C1 95 BE B5 D6 51 AF 6F 0E 49 90 41 61 4B E7
                            16-07-2006 23:02:00
                            16-07-2006 23:18:00
                            key: 86 A4 FE 21 8D 43 2C CC 17 D5 8B 07 E3 EF B3 E0
                            16-07-2006 23:35:00
                            key: 22 F7 EA 89 B9 BC D5 D4 A4 B7 5A 19 40 30 4B 9D
                            16-07-2006 23:47:00
                            key: 2D 01 19 48 9F 2A DB 72 98 F2 6B B3 24 C4 B6 59
                            17-07-2006 01:05:00
                            key: 80 1F 11 BB 92 1B 3E 33 3E 40 6B 8D A6 AF 47 14
                            17-07-2006 01:19:00
                            key: FC D9 95 9E 5A 75 F0 27 5E 38 29 F0 A0 97 26 03
                            17-07-2006 01:35:00
                            key: 24 08 5F EC D0 0D D9 04 DB C6 FE 81 67 49 84 29
                            17-07-2006 01:55:00
                            key: 51 9B B5 05 F3 CD 22 3F 8E 9D 53 55 7D F9 83 CB
                            17-07-2006 02:03:00
                            key: CF 2A 90 B6 5A 41 56 76 25 CD C8 A7 2B 12 EC 33
                            17-07-2006 02:21:00
                            17-07-2006 02:40:00
                            key: 77 04 C8 F7 31 15 95 79 CF A8 A6 AA 25 C5 10 D2
                            17-07-2006 02:52:00
                            key: E8 60 84 E1 28 87 E5 4C D5 4E 93 FC 42 24 11 76
                            17-07-2006 02:36:00
                            key: 05 C7 74 37 A5 57 C2 21 07 F8 6B 8F 71 34 06 46
                            17-07-2006 05:15:00
                            17-07-2006 06:12:00
                            key: EA E4 95 6C 5D F4 EE 63 DC 30 FA F3 80 3E F6 16
                            17-07-2006 08:56:00
                            key: E6 9F 38 71 71 CE 08 82 CA 4B D6 41 8D FC D5 F6
                            17-07-2006 09:38:00
                            key: 9C 22 42 BE 86 8C 21 C5 99 25 85 84 63 08 B1 FF
                            17-07-2006 11:20:00
                            key: BF CB E4 AE 7C 80 D0 CC 73 A2 FC 46 7E 3C 01 A4
                            17-07-2006 11:48:00
                            key: 46 04 6C E2 EE 0A 93 C3 56 7E 6E ED AE BB D7 57
                            17-07-2006 12:07:00
                            17-07-2006 12:32:00
                            key: 39 E9 7B A4 DD 4B BB AB E6 17 99 7E 48 C2 7B 70
                            17-07-2006 13:21:00
                            key: C0 44 C3 70 55 30 F9 18 0D 67 9E BA D9 34 63 3D
                            17-07-2006 13:49:00
                            key: DE 2E F5 51 CB B3 04 CF 9A 08 93 12 86 C9 FD EF
                            17-07-2006 14:11:00
                            key: 32 05 25 E3 1C B2 57 7D 14 80 C6 FB 9E AC 5D 51
                            17-07-2006 14:55:00
                            key: 66 C2 16 1B 35 CB CD 9A 6C 1B FA 2C 32 8A 57 47
                            17-07-2006 15:05:00
                            key: B8 08 41 22 DC 45 39 7A 0A 6B 3F 44 E9 91 0E EB
                            17-07-2006 15:23:00
                            17-07-2006 15:36:00
                            17-07-2006 15:50:00
                            key: 8B A7 63 95 C9 C1 B9 D3 B3 EC B4 AC 05 C6 B3 F3
                            17-07-2006 16:06:00
                            key: E4 94 8F F5 79 D4 BC 7B 43 17 CD 8F 8A ED FB 83
                            17-07-2006 16:17:00
                            17-07-2006 16:39:00
                            key: 07 00 0D CC 08 C5 5D F6 F4 E3 60 4D FA DF CF EA
                            17-07-2006 16:52:00
                            key: 20 29 93 9F 6D 9F 7F DB D5 B2 E4 B9 57 B5 1E 3F
                            17-07-2006 17:04:00
                            key: 98 B8 96 E0 83 3B D4 CE 5F 4B E6 02 A3 CD 18 81
                            17-07-2006 17:22:00
                            17-07-2006 17:33:00
                            key: 29 58 01 DB 4D DE 18 57 FD C5 92 02 5D 81 C0 51
                            17-07-2006 17:49:00
                            key: 3C 04 AE 6C EE 37 6C 76 94 C1 00 3A 4D 89 3D E1
                            17-07-2006 18:03:00
                            key: 1D 67 9F 6D A5 96 19 A9 33 6E 55 3D B1 F8 D6 20
                            17-07-2006 18:21:00
                            key: E3 44 F1 AC 64 7D 9F CA B7 93 1F BD E3 CD 80 0C
                            17-07-2006 18:40:00
                            17-07-2006 18:51:00
                            key: 08 84 B6 7B AC 97 5A F4 C2 D3 7A 40 54 10 3D F2
                            17-07-2006 19:04:00
                            key: 8C AA F9 63 E2 57 AB 5F 7A 9F 51 9B F1 D6 56 15
                            17-07-2006 19:23:00
                            key: A6 64 BB 6A 80 35 E8 23 B0 15 55 3F 91 CD 7B 01
                            17-07-2006 19:33:00
                            key: 1E 1E E9 BF D9 BD B1 D4 FF 77 2D 7D 7C 7E 0A 8E
                            17-07-2006 19:49:00
                            key: 7D 86 2E 61 9A 2B 5B 44 FD 27 2C 73 3C 48 68 31
                            17-07-2006 20:02:00
                            key: 81 A9 8F 5C 2D DF 2B 6C CB 65 D5 7C 43 C6 E6 D6
                            17-07-2006 20:22:00
                            key: 71 34 7A D2 E1 D8 7F 78 9A 24 F9 F6 F5 60 E8 32
                            17-07-2006 20:33:00
                            17-07-2006 20:55:00
                            key: 2E D8 71 F2 9E EE A2 C3 E6 9B 44 DF FC 61 79 73
                            17-07-2006 21:06:00
                            key: 39 75 C5 DE C9 9C 03 3C 35 9C 64 D8 9D E4 A5 7C
                            17-07-2006 21:22:00
                            key: 2D F8 F5 A9 B4 2E 7C B7 A9 68 44 3D C4 F7 15 FB
                            17-07-2006 21:34:00
                            key: 28 B9 B7 09 1A 7C F0 7C 84 30 59 C0 4A 93 72 B6
                            17-07-2006 21:50:00
                            key: B9 0D A4 1B 83 FC 1B 90 67 94 8C 41 C2 9F B2 A3
                            17-07-2006 22:09:00
                            key: FD 67 C5 5C 11 4F BA EB 90 B0 B0 39 CA CF 0B 65
                            17-07-2006 22:25:00
                            key: C4 23 A9 CC CB A2 41 40 A7 08 5B 50 25 D4 DD F3
                            17-07-2006 22:39:00
                            key: 1F 39 F2 03 C4 69 78 60 EE 41 A6 76 1B 51 63 54
                            17-07-2006 22:47:00
                            key: 5B 6D 79 CE 3E 2A 1D 4A 1E 0E AB F1 5B 2D A3 92
                            17-07-2006 23:08:00
                            17-07-2006 23:19:00
                            key: E0 F7 8C 3F E5 D9 13 E6 C9 8D 88 00 3B B2 AC 22
                            17-07-2006 23:36:00
                            key: 4A D8 2E 2B A7 FE 95 F4 8A D7 4E 07 D2 0F 6C 6A
                            17-07-2006 23:52:00
                            key: 58 B1 EE 79 8D 6F 5B 29 99 D2 6C 51 14 C6 87 77
                            18-07-2006 01:02:00
                            18-07-2006 01:24:00
                            key: B3 8F FD 42 F1 8F D2 F6 0D 4A 0D 1A 68 38 C4 4D
                            18-07-2006 01:38:00
                            key: 18 B0 D4 CA 4A C6 0A 00 98 A9 36 F4 0F E3 7D 93
                            18-07-2006 01:55:00
                            18-07-2006 02:05:00
                            18-07-2006 02:22:00
                            key: D3 79 15 5A 8B 86 E9 37 F1 28 59 DE BB FD 48 90
                            18-07-2006 02:33:00
                            key: 89 DC E9 63 90 C4 60 82 C6 15 85 DB D0 FD 31 90
                            18-07-2006 02:53:00
                            key: 72 2B AC 80 BB EF AD 0A EE E3 C0 AF 34 07 B9 7B
                            18-07-2006 02:15:00
                            key: 8B 21 21 18 80 A7 80 DC CF 1C 29 F3 A5 37 8B 3F
                            18-07-2006 04:46:00
                            key: F0 51 CE 4C 02 49 87 9D C9 81 AE AF EE D7 E2 E9
                            18-07-2006 06:10:00
                            key: 69 6A DF 3D 3A 9E CC 9F 41 1D 4B EE FA 15 EA C1
                            18-07-2006 07:40:00
                            18-07-2006 10:53:00
                            key: 8D C0 89 AC F8 09 55 A0 1E 12 B6 76 71 79 D2 5E
                            18-07-2006 11:06:00
                            key: 5A 13 D6 09 3E E9 4E 20 3C D8 43 DB EF F4 FF EC
                            18-07-2006 11:41:00
                            key: 45 1C 7C AF 2C DA E9 B9 27 3D 25 AA A7 73 4C D7
                            18-07-2006 12:18:00
                            key: F4 8E 6C 06 2E B8 5C DF 93 56 A7 D7 20 AC E8 ED
                            18-07-2006 12:54:00
                            key: 0B 8C 6E 4B 9A BD 1B 84 A3 0B DF 13 72 5A 3F 65
                            18-07-2006 13:15:00
                            key: 24 D9 5A D4 40 19 E7 9E 4F 0D 95 D2 66 69 18 08
                            18-07-2006 13:36:00
                            key: 9C 44 2F 31 39 EB 97 4E F5 EF 2E 0D 5E DE 72 02
                            18-07-2006 14:03:00
                            key: 23 DE 77 ED 9D E0 22 44 5D 41 83 9B 7D E3 09 59
                            18-07-2006 14:46:00
                            key: E4 50 01 04 4A BF 59 69 61 43 17 13 33 B8 26 C1
                            18-07-2006 15:04:00
                            key: 7E 88 D9 85 94 F2 0D 97 53 35 9F BF 49 F3 1F 43
                            18-07-2006 15:20:00
                            18-07-2006 15:34:00
                            key: CA 69 39 BB 20 23 A9 82 6A 4B 1A 46 C3 16 7D B8
                            18-07-2006 15:47:00
                            key: 3D E9 57 2B 5F 5A C9 F0 2B 0A 9F 4A 03 7A 4B 0D
                            18-07-2006 16:10:00
                            key: 93 EA 81 D2 4D CE 41 B5 A1 F9 8E 7E 09 F0 CC 20
                            18-07-2006 16:19:00
                            key: 6A 39 25 18 69 47 C0 EA C3 EA C7 86 57 39 E9 CE
                            18-07-2006 16:36:00
                            18-07-2006 16:55:00
                            key: A5 07 EC 82 1F 95 1F 56 45 E9 DB 45 91 05 4B E4
                            18-07-2006 17:03:00
                            key: F0 AE B9 39 68 37 BC 49 F0 99 EF D7 68 D8 DB 8A
                            18-07-2006 17:19:00
                            18-07-2006 17:40:00
                            18-07-2006 17:49:00
                            18-07-2006 18:10:00
                            key: CB F8 2E B0 2E 44 07 DF 85 C7 4C 70 63 05 73 EF
                            18-07-2006 18:22:00
                            18-07-2006 18:36:00
                            18-07-2006 18:49:00
                            key: 98 86 17 74 A7 B6 2A 70 DA 95 A1 C7 3A 16 0B 58
                            18-07-2006 19:02:00
                            18-07-2006 19:24:00
                            key: BB 51 A1 85 6C 99 DC 41 58 74 D1 75 74 26 7D 9C
                            18-07-2006 19:37:00
                            18-07-2006 19:53:00
                            18-07-2006 20:02:00
                            key: 70 23 75 DE 3F 77 E5 B1 F1 71 D2 BC 8A B2 54 BA
                            18-07-2006 20:23:00
                            key: 59 F1 04 96 AD 2F 23 1F D3 85 D2 79 77 77 52 34
                            18-07-2006 20:35:00
                            18-07-2006 20:55:00
                            18-07-2006 21:08:00
                            18-07-2006 21:24:00
                            key: 86 1F FD 8D DA 31 2C 26 22 B9 FF 27 42 0A 3F 58
                            18-07-2006 21:34:00
                            18-07-2006 21:47:00
                            key: 7E AD DF 02 6C 1B A9 4E B4 BD 93 77 43 B4 3F 43
                            18-07-2006 22:04:00
                            key: 08 D5 4C 31 AD 9C D3 62 9C 33 5D 7D DA 04 AB 29
                            18-07-2006 22:23:00
                            key: BE C9 38 6F 2B 33 8D CF A7 05 2D 79 72 42 8B EF
                            18-07-2006 22:37:00
                            18-07-2006 22:51:00
                            18-07-2006 23:10:00
                            key: 92 C7 25 5A CC 40 27 E4 55 8F 61 38 F6 AF 2C 64
                            18-07-2006 23:23:00
                            18-07-2006 23:40:00
                            18-07-2006 23:50:00
                            key: 4B AD 23 83 94 F1 8F DB 8A B6 07 99 F7 E2 B7 CC
                            19-07-2006 01:03:00
                            key: 7F 20 CF 63 34 0E 78 F4 B9 B7 E7 5A 3E 3E 5A 3C
                            19-07-2006 01:17:00
                            key: D5 2D 3F E7 A7 C5 2E 66 86 CE FB E3 DB 7F 9B 89
                            19-07-2006 01:37:00
                            key: 4B 61 D2 7A 90 5F CE 49 C9 E4 C8 B7 8D 22 DB 23
                            19-07-2006 01:47:00
                            key: A1 89 67 2B 6B F1 C9 5F EF 95 50 15 58 D3 22 C3
                            19-07-2006 02:07:00
                            key: 3C E5 93 38 C4 B5 25 FE B9 42 60 29 0D 19 C7 03
                            19-07-2006 02:23:00
                            key: F2 48 0C 74 83 C6 17 C4 3C 25 7B 0E 65 C3 B7 31
                            19-07-2006 02:32:00
                            19-07-2006 02:55:00
                            key: B5 55 5F 3D 39 3C DE 49 7D A8 AF A4 BD A0 C4 B7
                            19-07-2006 02:34:00
                            key: C8 13 A4 5E 37 85 C9 88 B9 37 CA 0C 38 07 9D F4
                            19-07-2006 05:31:00
                            19-07-2006 07:08:00
                            19-07-2006 08:18:00
                            key: 9B EE 9C 98 7E F8 85 3C 57 B0 63 43 F9 B8 45 37
                            19-07-2006 10:23:00
                            19-07-2006 11:09:00
                            key: A0 B0 B9 CC C5 18 6E E2 19 14 37 19 FD C3 1F AB
                            19-07-2006 11:42:00
                            19-07-2006 12:08:00
                            19-07-2006 12:45:00
                            19-07-2006 13:07:00
                            key: 26 09 E6 AE 98 F4 B7 F8 47 E5 2E C8 3D A4 11 A6
                            19-07-2006 13:42:00
                            19-07-2006 14:02:00
                            key: 57 2A B0 BF DA A2 3F 35 A6 9C 64 07 72 43 4F EA
                            19-07-2006 14:38:00
                            key: DE F0 A7 21 28 9B C2 84 A7 DC AE 0F 25 27 56 99
                            19-07-2006 15:10:00
                            19-07-2006 15:17:00
                            19-07-2006 15:37:00
                            19-07-2006 15:51:00
                            key: 3E EE F5 E8 01 0D BF CB 68 09 44 28 C1 AF FB 80
                            19-07-2006 16:02:00
                            19-07-2006 16:24:00
                            19-07-2006 16:33:00
                            19-07-2006 16:50:00
                            key: 71 E1 8D 99 16 15 9E A7 6B DB 1F A4 05 11 B8 20
                            19-07-2006 17:09:00
                            19-07-2006 17:23:00
                            19-07-2006 17:36:00
                            key: 21 C3 98 68 EE 03 4C EC 55 5C 67 07 56 73 36 A3
                            19-07-2006 17:50:00
                            key: 59 04 3A 39 7D 86 35 BA D6 15 DC A9 53 BB C1 A9
                            19-07-2006 18:09:00
                            key: 50 3A C4 26 59 A6 1F F1 06 AE 6F B9 E0 B5 45 E7
                            19-07-2006 18:23:00
                            key: E9 75 50 A1 31 66 99 57 4D 01 9B 4C E5 01 0C 1E
                            19-07-2006 18:40:00
                            19-07-2006 18:54:00
                            19-07-2006 19:07:00
                            key: 1C 6B A0 9E 4E E4 EC 71 B8 D7 5A 81 BE 51 FF 1E
                            19-07-2006 19:23:00
                            key: 65 87 04 F7 B7 9B D0 84 A1 79 D1 AA 91 61 70 39
                            19-07-2006 19:39:00
                            key: 85 C7 EB D6 17 81 D0 C8 87 32 CE 67 D7 A9 47 AC
                            19-07-2006 19:52:00
                            key: 91 7F 0A D0 0C E5 3C C7 7B 62 0F CD F4 D7 50 9A
                            19-07-2006 20:04:00
                            key: E7 4E 47 75 C4 74 76 79 A1 D6 32 1C 34 3D D6 B0
                            19-07-2006 20:17:00
                            19-07-2006 20:38:00
                            19-07-2006 20:49:00
                            19-07-2006 21:07:00
                            key: 9B D8 DD 8B 11 B8 EC DD 1B 1C 62 87 E8 82 AA 3D
                            19-07-2006 21:19:00
                            19-07-2006 21:33:00
                            19-07-2006 21:55:00
                            19-07-2006 22:05:00
                            key: 32 F3 1B 35 6D 2D 87 C0 BD 2D 4F 1E 3A 5E 0C 7A
                            19-07-2006 22:21:00
                            key: 2C 77 21 73 8A 7F EE 41 C2 18 2F D3 48 87 3D 08
                            19-07-2006 22:37:00
                            key: 5D 5D F5 70 33 17 87 3E 59 72 83 5B A3 24 AD 75
                            19-07-2006 22:53:00
                            key: B4 73 8C E1 AE 4E 21 13 37 89 70 8D FE 1B 41 D8
                            19-07-2006 23:04:00
                            key: E8 9D F3 85 A1 9D CF 08 E6 4A 06 11 7A 44 B7 10
                            19-07-2006 23:20:00
                            key: ED 5B 73 65 FC 7B B7 AE 78 80 7E A0 02 15 CD 9B
                            19-07-2006 23:36:00
                            19-07-2006 23:54:00
                            key: E7 AA 0F A5 08 ED 6B 4A 7D 84 2B A1 77 AE 9A 6A
                            20-07-2006 01:10:00
                            20-07-2006 01:23:00
                            key: 0A 06 52 C6 5E 8D 3A 44 33 7B 7E 0E 74 0A EB DD
                            20-07-2006 01:35:00
                            key: 28 DB 33 B0 3C 3A AF 79 9D 57 DD 1C 3A AA 00 90
                            20-07-2006 01:48:00
                            key: 97 40 03 96 0F 2B DD AE A9 35 4E 55 A3 8A 28 E9
                            20-07-2006 02:10:00
                            key: 9E 98 98 36 A4 5F A5 48 E2 75 28 5D 10 59 CB 21
                            20-07-2006 02:23:00
                            20-07-2006 02:32:00
                            20-07-2006 02:49:00
                            20-07-2006 03:43:00
                            key: F9 98 DD C2 50 B8 4B B6 06 4F 4F 86 56 09 26 90
                            20-07-2006 03:55:00
                            20-07-2006 06:53:00
                            20-07-2006 07:40:00
                            key: 98 C2 A0 73 8B 21 44 60 41 26 7C 73 9D 75 23 77
                            20-07-2006 09:21:00
                            20-07-2006 11:20:00
                            20-07-2006 11:33:00
                            20-07-2006 12:16:00
                            20-07-2006 12:47:00
                            20-07-2006 13:06:00
                            key: 07 82 DF A8 6B 1D 08 0C 12 01 7E 34 E3 2B EA 5E
                            20-07-2006 13:55:00
                            20-07-2006 14:07:00
                            key: 98 7B A0 19 23 28 96 BA 00 AA 00 8D B1 62 A0 07
                            20-07-2006 14:33:00
                            key: 94 AC 99 66 2D 2E BC 4D 69 17 3F CB EB 10 E7 F0
                            20-07-2006 15:09:00
                            20-07-2006 15:18:00
                            20-07-2006 15:39:00
                            20-07-2006 15:55:00
                            key: 00 68 FF 72 52 F7 38 40 0A 1C 94 6D F6 BD F6 DC
                            20-07-2006 16:05:00
                            20-07-2006 16:21:00
                            20-07-2006 16:40:00
                            20-07-2006 16:49:00
                            key: 52 20 CB A8 C6 B4 DF 58 F4 A5 4F 79 BC C1 FF 82
                            20-07-2006 17:06:00
                            key: 01 50 B6 22 68 F7 33 DE 13 35 CA 17 36 F6 66 FB
                            20-07-2006 17:17:00
                            20-07-2006 17:37:00
                            20-07-2006 17:55:00
                            20-07-2006 18:05:00
                            20-07-2006 18:25:00
                            20-07-2006 18:37:00
                            20-07-2006 18:54:00
                            key: 60 D6 62 A0 B8 1D 77 9D AA BE 0C F9 8D 4E 57 49
                            20-07-2006 19:07:00
                            20-07-2006 19:21:00
                            key: 96 69 FB BC 11 9A 29 21 CC CA B2 69 59 32 60 11
                            20-07-2006 19:39:00
                            key: 1D 3A DF 4F 11 35 F7 59 F8 D8 F9 58 8C 03 58 CB
                            20-07-2006 19:47:00
                            20-07-2006 20:07:00
                            key: 1C 22 39 D7 B4 19 CF B9 4C BD 79 57 64 22 73 1C
                            20-07-2006 20:19:00
                            20-07-2006 20:36:00
                            20-07-2006 20:48:00
                            key: B6 1B 7C 1D FC 66 33 64 DC 0C 85 A1 8A AC 94 E1
                            20-07-2006 21:09:00
                            20-07-2006 21:18:00
                            20-07-2006 21:39:00
                            20-07-2006 21:49:00
                            20-07-2006 22:03:00
                            20-07-2006 22:19:00
                            20-07-2006 22:33:00
                            20-07-2006 22:47:00
                            key: 8E 6E 38 64 69 85 54 C0 61 25 4F 87 05 A8 DA 12
                            20-07-2006 23:07:00
                            20-07-2006 23:19:00
                            20-07-2006 23:36:00
                            20-07-2006 23:54:00
                            21-07-2006 01:06:00
                            21-07-2006 01:25:00
                            key: 84 DC FF 3D 74 93 C3 89 17 A1 98 96 2D 91 30 7D
                            21-07-2006 01:33:00
                            key: B8 4C B1 A0 A1 20 9E 32 4F 64 C2 D8 4F B9 49 78
                            21-07-2006 01:47:00
                            21-07-2006 02:05:00
                            21-07-2006 02:22:00
                            key: 4F B5 92 CE 2C 21 4C 93 3B 13 A0 87 5F 3F 62 BF
                            21-07-2006 02:34:00
                              Ora cum este ? GMT + 2 ? GMT + 3 ?
