TwinhanDTV Sat-CI & Pinnacle PCTV Sat-CI
    Am citit pe undeva ca Pinnacle PCTV Sat-CI este de fapt OEM Twinhan.
    Stie cineva mai multe despre asta ? Ma intereseaza in special daca driverele de Twinhan se "potrivesc" pe Pinnacle !
    Thx !
    the later Version of Pinnacle PC TV sat were exactly the OEM of Twinhan, but the recent version is a bit modified copy of it. Under ProgDVB Pinnacle still works fine if we select twinhan drivers.
      the latest version of Pinnacle TV SAT uses Composite Video/S-Video out pins.
        both the Pinnacle and Twinhan use the Connexant fusion 878 chips.
          Thx Saed for info
          Pinnacle PCTV Sat interface for AltDVB is ready and tested, but I'm afraid will not be compatible with Twinhan because it use other frontend chip (DTV20023)
