Noul My Theatre 3.2 !
    Gasiti la http://www.dvbcore.com noul MTcare are ac noutati:
    5 nov 2003 - MyTheatre v3.02
    - FIXED: hangup while transponder scanning.
    - MAY BE FIXED: sometimes not fully unloaded from memory after exit.
    3 nov 2003 - Finally, MyTheatre 3 released! Registration open.
    Major new features in v3.01:
    - added support of PCTVSat.
    - added support of Positioner (DiSEqC v1.2)
    - TwinHan code totally rewritten (all card versions now supported)
    - Enhanced TwinHan Remote support (see MTRemote)
    - several instance of cards supported (i.e. two TwinHan cards)
    - AC3 fixed.
    - many other features added, and many bugs fixed.
    Pacat ca e cam scump (40 Euro) dar gasim noi un cra*k !
    ...ei asa se gaseste si noul WatchTVPro ! (ultima versiune)
    ,,*** Time is an illusion ! ***,,
      Salut!
      mai are cineva probleme cu dezarhivarea programului? ( bad CRC?) . Ceva solutii? l-am copiat pana acum de 3 x si nimic .... http://www.dvbcore.com/files/MyTheatre.zip
