TBS 5522SE + Raspberry Pi4
    Salut
    Detine/foloseste care combinatia asta de device-uri ?
    Deocamdata am doar tv tunerul TBS 5522SE si as dori sa cumpar un Raspberry Pi4 si sa instalez/folosesc LbreElec 9.1.002 alpha dedicat pt raspberry pi4
    Insa in videoclipul de mai jos , la minutul 5.18 , adica la - Setari - Iesire Video - se poate vedea ca nu se poate mai mult de 4K/30
    - https://www.youtube.com/watch?v=6mxY...ature=youtu.be
    De fapt si cei de LibreEelc confirma acest lucru si metioneaza ca ar trebui modificat un fisier txt , citez :
    - Change for Raspberry 4:
    With LE 9.1.002 and later you need to add hdmi_enable_4kp60=1 to your config.txt if you want to use 4k output at the RPi4.
    Before you needed hdmi_enable_4k=1 that is now deprecated.
    Stiti unde sau cum se modifica acel fisier sau l-ati modificat deja....... , cei care detin un raspberry pi4 si folosesc libreelec 9.1.002 alpha dedicat pt raspberry pi4
    pi versiunea 4 e foarte nou, nu il gasesti in foarte multe magazine. se sugereaza rabdare si eventual si niste tiutiun
      This file is normally accessible as /boot/config.txt from Linux, and must be edited as root. From Windows or OS X it is visible as a file in the only accessible part of the card. If you need to apply some of the config settings below, but you don't have a config.txt on your boot partition yet, simply create it as a new text file.
      https://www.raspberrypi.org/document...on/config-txt/
      nirolf likes this.
      Red Green: If life gives you lemons, throw 'em into a quart of vodka.
        Am scos fisierul ''config.txt'' din imagine si am adaugat respectiva linie
        Acum nu stiu daca e bine sa o las fara semnul # sau sa il pun inainte , vezi cele doua variante
        1 -
        # Force HDMI even if unplugged or powered off
        # hdmi_force_hotplug=1
        hdmi_enable_4kp60=1
        2 -
        # hdmi_enable_4kp60=1
        nirolf likes this.
          In config.txt se pot adăuga comentarii sau valorile de configurare existente pot fi comentate și dezactivate, pornind o linie cu caracterul #.
          Orice modificare va avea efect numai după reboot Raspberry Pi.
          Foloseste varianta 1.
          xyzcv and nirolf like this.
            salut. am un raspbery pi 4 , pentru a ma conecta la el ce program pot sa folosesc //?
              PuTTY
              SSH si telnet client
              The default login for Raspbian is pi with the password raspberry
              Vezi aici https://www.raspberrypi.org/document...ssh/windows.md
