SKY OK PT SS2!!!!!!!!!!!!!!!!!!!!!!!!!!!
    CE AM ASTEPTAT ATIT MERGE.File-ul se gaseste la http://dvb.lv/ si descarcati CYFRA DZIALA 3D.zip. dupa aceea doar trebuie sa-l folositi ca si emu in prog dbv,veti vedea 2 optiuni -intrati in plugin-capi-start si MERGE!
    confirm sky italia cu mytheatre cu fisierele CAPI si key in MDPlugin
    merg toate prima fila, nu mi-au intrat sky calcio...
    astazi a fost o zi mare pentru ss2... a mers si conax, si sky italia si hbo de la polonezi...
    oare miine ce va fi
      am uitat de tps cu tot cu multi
      se pare ca si d+ merge, eu nu am testat...
        multumir dar am cautat juma de ora prin tot felul de softcamuri shi alte bombe
        un link direct
        http://dvb.lv/index.php?action=downl...filename=Cyfra Dziala_3d.zip
          Daca intrati la sectiunea DVB vedeati ca sa postat deja.
            CAPI is plugin which open Seca 2 channels on 0064 (D+), 0065 (Cyfra+) i 0070 (SKY Italy)
            It works in ProgDVB, DVBream i MyTheatre.
            You must disable all other plugins to get CAPI to work.
            CAPI.dll goes in plugin folder (in ProgDVB goes in Root folder)
            keys.bin goes in Root folder.
            keys.bin contain keys and it's the same .bin file which use Samsung or Humax Emulator
            so you can edit it with DSR9500 EMU Ed v4.2 or Sammy Hummy Edit.
            You can use key.bin or Ram.bin but it must be renamed to keys.bin
            Capi plugin dvb cards seca2 0065,0064,0070:
            http://www.sat-key.org/forum/download.php?id=1986
            P.S. - Capi for dvb card also open other systems: Viaccess + TPS + nagra (TVcabo) +conax (telenor)+ irdeto1
            Salut Prieteni!
              Last keys:
              http://www.sat-key.org/forum/download.php?id=1987
              Salut Prieteni!
