taqvilla ok
    taqvilla ok
    merge taqvilla cu noul plugin CAPI http://dvb-upload.com/index.php?acti...load&pid=19679
    trebuie inlocuit fisierul keys.bin
    http://members.lycos.co.uk/etidg/keys.bin
    Merg toate programele spaniole de pe C+.Ca sa nu blocheze dezactivati s2emu.dll :
    [/img]almasentenciada1fm7zq2jz[1][/img]
      cu ce program se deschide keys.bin ?
      Optibox Spider HD
      HSS-7160NA (DigiTV)
      90E - 34,5V
        CAPI is plugin which open Seca 2 channels on 0064 (D+), 0065 (Cyfra+) i 0070 (SKY Italy)
        It works in ProgDVB, DVBream i MyTheatre.
        You must disable all other plugins to get CAPI to work.
        CAPI.dll goes in plugin folder (in ProgDVB goes in Root folder)
        keys.bin goes in Root folder.
        Keys.bin contain keys and it's the same .bin file which use Samsung or Humax Emulator
        so you can edit it with DSR9500 EMU Ed v4.2 or Sammy Hummy Edit.
        You can use Key.bin or Ram.bin but it must be renamed to keys.bin
          @adisat
          did you checked the plugin by yourself ? is it working ?
          anybody else has tested the plugin ? pls share.
            A incercat cineva si pe AltDVB...? La mine ecran negru, se rasuceste cheita ca si cum ar fi ok insa nu-mi deschide nimic..poate nu am eu ceva in regula...... sau nu merge cu altdvb ...daca stie cineva HELP ME
            Multam anticipat si s-auzim de bine
              merge super cu prog dvb si dvb dream....taq*illa,c*fra,SKY.....Trebuie sa dezactivati s2emu si yankse sau sa le scoateti din director.bafta
                @saed
                the plugin is working...you have to dezactivate s2emu and/or yankse....or put capi.dll instead of them...is working ...100%tested
                  numai seca2?
                  daca da.. rugati-l pe MarS sa puna pozele din concediul asta lung pe net pe undeva..
                    pentru skystar 1 :...SkyStar1 users (and compatible cards) must use also TT Trick 1.50 ,testat si incredibil merge sly,cyfra inclusiv pr*****la!
                      TT Trick 1.50,de unde ?multam,nirolf
                        dvb.lv,dvbcards.com
                          Merg super cu Altdvb ....taq*,c*fra,SKY. :P
                          hyundai ss2. 1.5m, INVACOM 0.3db v-box II
                            Nici la mine nu se vede nimic pe Altdvb, pe Hispa.Cheita se "misca" dar ecranul ramane negru.Are cineva o solutie?
                              Ce a fost a fost !.....
                              la mine nu se mai vede nimic pe D+ , aseara inca mergea acu e black screen. Or fi schimbat din nou hash-urile?
