BlindScanner for SkyStar2 Rev. 2.3
    O noua jucarie pentru cei pasionati de receptia DVB.In speranta ca nu o sa fie nimeni suparat ca nu am pus si explicatii in Romana:
    .:: SAT BlindScanner ::.
    This toy is working ONLY with SkyStar2 Revision 2.3
    (using MITEL tuner with TSA5059 frequency synthesizer
    and VP310 demodulator/channel decoder)
    History:
    04/01/2005 - First public version
    Scope:
    * Find some feeds
    * Generate transponders .ini for your favorite DVB App
    Performance:
    * Full ASTRA 19.2 scan was performed in 63 seconds
    (using profile "MCPC with SR 20-30 K.bsp" )
    Operation:
    1) Edit LOF settings & DiseqC
    3) Select a profile and press [Load]
    4) Adjust other settings,if needed (eg. Freq. range or polarity)
    5) Press [Start]
    6) Wait...
    7) Select current sat. and save discovered transponders
    Hints:
    * Do not mix low symbol rates (< 10000 Ks/s) with
    high symbol rates
    * Use freq. increment step lower then smallest SR selected
    * SR Detection is not perfect (maybe a hardware bug).
    Edit "SymRate.fix" to correct detected symbol rates
    * If detected frequency is constantly shifted (compared with a
    good .ini file ) adjust LOF HI/LO settings and scan again !
    (maybe your LNB oscillator is not stable with temperature)
    * If you are not using card for a long time press [Sleep] button
    to switch VP310 to Low-Power mode
    ( SleepMode-> 30ŚC colder then in "normal" mode )
    Know bugs:
    * Sometime VITERBI decoder cannot get lock.FEC will be "NA"
    Tested on:
    P4 3GHz (with HT) & Athlon XP 2600+
    Windows XP Pro + SP1
    SkyNet.sys Versions: 4.2.08, 4.2.11 & 4.2.30
    ..and of course SkyStar2 Rev. 2.3
    Download:
    Happy Feed-Hunting !
    [Altx]
    Later edit: http://www.********.ro/upload/BlindScan.zip
    Sa ne traiesti Altx
    Am reusit sa-l testez pe Hispasat. Se misca f. bine.
    La mai multe surprize !
    ______________Incet ne facem oameni mari !______________________
    Antena 1.5 primefocus, Box HD Vu+Twin
      Pentru cei care nu au Yahoo (sau nu vor sa se inregistreze pe inca un grup) un link direct:
      Code:
      http://www.dvb.lv/index.php?action=downloadfile&filename=BlindScanner_SS2_Rev23.zip
      Daca aveti sugestii legate de program nu ezitati sa le postati aici ! Thx !
        Frumos .. 59 secunde Astra 19est
        Bravos
          L-am incercat si eu si merge si pe Driver 4.2.10...
          Spor la munca in continuare, Altx, si asteptam o noua versiune la Altdvb!
            Altx, de ce nu reusesc sa scanez unul din satelitit (de ex Nilesat sau Turksat) care le-am scanat cu Blindscan ? Am introdus fisierul .ini generat de Blindscan in AltdvbSatFiles\Transponders dar cind incercsa scanez cu Altx efectiv nu vede noul satelit.
            Trebuie facute ceva schimbari la fisierul generat ?
            Felicitari pentru program!
              la mine inainte de a porni imi da o eroare de genul: error init card - lock authorize. dupa care porneste dar nu vrea sa faca scan ca zice ca nu am skystar 2 2.3, dar chiar asta am inauntru, doar ca nu am reusit sa o fac inca sa mearga...
                Ce drivere ai instalat? Daca nu reusesti sa prinzi nimic cu nici o aplicatie e posibil sa fie placa "blocata". NU presupune ca e blocata si NU incerca sa o deblochezi pana nu esti sigur 100% ca aceea e cauza! Risti sa ramai fara ea. Verifica intai ca restul componentelor instalatiei sunt corect montate/pozitionate si functioneaza.
                Pentru erori de calculator e bine sa dai si configuratia pe care ai testat. Revin-o cu detalii si se rezolva problema...
                Imi amintesc ca si mie mi-a facut la fel, dar dupa ce instalasem driverele de pe cd-ul "original" (4.2.2). Manifestarile au fost:
                - in progdvb aveam semnal (80%+) dar nu deschidea nici un canal
                - in DVB Viewer (app de vine pe cd) nu deschidea nici un canal si zicea ca sunt "locked"
                - la scanare din setup4pc dadea "PMT Table not found" (parca) pe orice frecventa (avea semnal, nu primea nimic)
                Schimbarea driverelor NU a rezolvat problema, dar mai intai verifica ce am scris mai sus.
                PS. Doar acum am vazut si intrebarea de le SS2 blocata
                  cum pot sa bag .ini creat de blindscan in MyTheatre?
                  de loc...
                  ichsehwaswasdunichtsiehst
                    poti bag si in MT tre sa dai import la fisieru ini in fereastra in care faci scanarea canalelor in MT. Bafta
                      aaahh, ok, mersi mult
                        dead links
                        1,1m skystar2 rev 2.3
                          Incearca aici : http://www.********.ro/upload/BlindScan.zip
                          100% va merge .
                            contacting Altx
                            How can I contact author of Blindscanner?
                            If someone knows, email in my profile is valid.
                              Send a Private Message to : altxro
