intrebare
    intrebare
    unde gasesc prog. altdvb?
    poate cineva ma ajuta?
    http://altx.dap.ro/Alt-Dvb.htm
    whitesnake.com
      linkul nu mere
      Network Error (tcp_error)
      A communication error occurred: "Operation timed out"
      The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time
        la mine da
        tocmai l-am verificat...
        ciao
        whitesnake.com
          full: http://altx.dap.ro/Alt-DVB_Full_20040409.zip
          up: http://altx.dap.ro/Alt-DVB_Update_Beta105.zip
          up: http://altx.dap.ro/Alt-DVB_Update_Beta106.zip
          si
          http://altx.dap.ro/TsOffDec_20040416.zip
          up: http://altx.dap.ro/TSOffDec_20040501_Update.zip
          ciao
          whitesnake.com
            la mine da
            ciao
            can u translate it pls.
            i've just started learning romanian
            ciao
              just now i checked the links and "mere.. mere... "
              thanks a lot for the alternate links, its a big help also..
              ciao
                man! you were serious about learning Romanian!?! lol!
                whitesnake.com
                  i was damn serious man...
                    saed ..... from where are u learning Romanian ..............
                    good luck to u for that
