yankse 1.30 is out !!!!!!!!
This topic is closed.
    http://www.yankse.com/download.php?view.1
    enjoy
    Da, e acolo
    Deseara am sa-l testez.
    PS. mai trebuie niste fisiere ca sa mearga pt. noua "functionalitate". Dar fara munca nu se poate...
      yankse 1.3.0?
      merge si d+ de pe astra?
        Abia deseara pot sa testez.
        Cica ar merge.
          l-am asteptat aseara.........dar nu a aparut decat pe dimineata.......
          testam deseara.......... :P
            am auzit ca cel mai bine merge cu dvbdream 0.8.2..........
                primele impresii:
                freex tv merge numai sunetul (imagine NADA)
                pachetul tps de pe hotbird nu mai merge cu acest yanksee.(le vede ca viaces2 pe cand cel vechi le vedea ca tps crypt si mergea boboc)
                la digital+ si sky italia BEZNA ca in nuca.
                asteptam si alte impresii
                respect
                Fuck me... and I`ll fuck you back!
                  revin:
                  dupa ce am luat un hash nou merge sky italia (nu chiar toate) unele sunt cu cheie 9c si nu merg.Freex tv si-a revenit. Tps'urile nu merg in continuare.
                  digital+ .....nimic.
                    Confirm pt. TPS 08 (No keys) Prov. ID V2 ARABESQUE
                    TPS-uri nefunctionale (Eurosport France, France2, etc......)
                    Majoritatea posturilor italiene in functie. D+ nu functioneaza. Totul este conceput pentru hash_0070.
                      123
                      http://www.dvb.lv
                      Tab-1-complete_mt.zip
                      Please, don't download unless you know what it is for! It is a file for test purposes only with new version of Yankse. If needed, the proper one will be upload a bit later.
                      INTERESANT
                      PT CONFORMITATE ROWAREZ(CORBUT CEZAR MANASE)
                        ss2
                        Mai trebuie:the new MaskTable for provider 0070 (sky italy) and the updated HashTable (also for 0070) with the new table 9X
                        Uitati ce mai scrie aici:
                        The long expected release of Yankse 1.30 is out. It features Via2 decryption (should work on NTV+ if the keys are known) and big enhancement for Seca2 decryption (new nanos) for the Italian package. As always, it comes in two flavors: the W98 version working on all Windows version (W98/ME/W2K/XP) in non-unicode mode, and the Unicode enhanceed version working only on W2K/XP platforms.
                        Choose the one which suits you best.
                        You need some updated files for Seca2: mainly the new MaskTable for provider 0070 (sky italy) and the updated HashTable (also for 0070) with the new table 9X.
                        These files are available on the usual upload centers, for instance:
                        dvb-upload
                        dvb.lv
                        Take life the way you go!
                        prays
                          observatiile mele :
                          -nu merg posturile radio
                          -nu deschide citeva canale (mtv hits, gradnfratelo...)
                          -pe primaf**a nu deschide cite2-3 programe prin rotatie
                          -si curios pe TPS imi arata cheie 'v2 invalid' dar surpriza : le deschide
                            salut
                            Mah ce dreaq suntetzi asha pretentioshi nu stiu ,este adevarat ca mai sunt unele buguri dar trebuie sa spuneti toti uraaaaa se vede shi inca destul de multe, de cativa ani seca2 era infailibil shi uitasem cum mai arata canalele italiene,deh visul s-a implinit ,sa vedem pina cand ,important ca in yankse scrie frumos shi al dracului de relaxant s2,tele+,eu zic sa ne bucuram cu totii ,eu ma multumesc cu munca pe rupte a celor care se zbat cu adevarat,iar noi cei care luam cireasa de pe tort suntem cei care sunt nemultumitzi,deh nu se vede tot ,se vede numai aia sau cealalta,bla bla bla
                            Multe multumiri lui Vlinders shi celorlalti care ne-au luminat ecranele cu seca 2,restul de buguri sunt convins ca se vor rezolva
                            propos ilav poate pentru tine emit necodat TPS-urile zi-ne shi noua secretul
                            PT CONFORMITATE ROWAREZ(CORBUT CEZAR MANA$E)
                              Uraaaaaaaaaaaaaaaaaaaaa!
