Help!!! Problema MTV ASTRA!!!
    Sal ...
    Folosesc SS2 + Prog DVB 4.38.6 + yan ... 1.23, etc.
    Odata cam la 5 minute se rupe sunetul scurt pe MTV Hits, totusi cam deranjant daca vrei sa faci captura.
    Stie cineva ceva? Codecuri?
    Multzani,
    ovex
    ss2
    Incearca programul nou:
    http://www.technisat-daun.de/download/en/soft/869.zip
    Poate...
    dm500
      DVB
      Poate te ajuta cu ceva.Eu am doar ver 4.36 si yan ... 1.22 si merge bine pe postul indicat de tine. Foarte rar imi apare o decalare a imaginii de sunet dar se intimpla cind pe PC mai rulez si alte programe concomitent cu ProgDVB-ul si in special cu GordianKnot sau fac download de pe net cu Shareaza.Salut.
      TechniSat DVB receiver software
      Version 4.2.11 (05/2004)
      Copyright (C) TechniSat Digital GmbH
      Contents
      This README.TXT file provides information on the following topics:
      - Support Information
      - Requirements
      - Trouble-Shooting
      Support Information
      For the latest information on products and support,
      please visit our homepage: http://www.technisat.de or http://www.technisat.com
      Owner of a box that is bundled to a service like Europeonline, Netsystems, OpenSky
      skyDSL,Filiago-DSL or T-DSL via Satellit should contact the service provider's support
      directly regarding service settings. Please review documentation of the service
      provider to get detailed contact information.
      Requirements
      PCI Products:
      - Pentium III 700 MHz
      - 256 MB RAM
      - 30 MB free hard disk space
      - 1 available PCI slot (do not use the one directly under AGP graphic card)
      - 3D graphic card recommended (with hardware overlay support, up to date driver)
      - Sound Blaster compatible audio card
      - Operating Systems:
      - Windows 98 SE
      - Windows Me
      - Windows 2000 Professional/Server
      (Service Pack 3 or higher recommended)
      - Windows XP Home/Professional
      - Windows 2003
      - Additional Software needed
      - min. Internet Explorer 6
      - min. DirectX 9
      - min. MediaPlayer 9
      USB Products:
      - 256 MB RAM
      - 1 available USB port (must be connected directly to PC, not via USB hub)
      - 3D graphics card (with hardware overlay support, up to date driver)
      - Windows 98 SE
      - Windows Me
      - Windows 2003
      - min. DirectX 9
      Trouble-Shooting
      Further help to most known problems can be found inside the FAQ documents
      on the installation CD. The documents are PDF so the Adobe Acrobat Reader
      is required!
      Take life the way you go!
      prays
        Am si eu o mica sugestie!
        Am inteles ca yan... 1.23 ar avea ceva probleme!
        Eu merg cu 1.22 si nu am probleme, incearca si tu cu 1.22.
        Noroc!
          Mersi de raspunsuri ...
          Am trecut la 1.22 si parca merge mai bine. Cu 1.23 vedeam Taquilla ... dar acum nu mai are rost.
          Folosesc Intel Pentium IV la 2.4 GHz cu 512 MB RAM si ma gandeam ca problema poate fi din codecuri. Nu folosec tampenii de genul ACE MEGA CODECS care iti da peste cap alte aplicatii (ex. capturi de pe camera video si prelucrare - iti vine sa urlii ), dar instalate separat: DIVX, XVID, FFDSHOW, Elecard MPEG2 Codecs si nVDVD + codecs. Cand le folosesc ultimele din sirul asta, miscarea este mult mai reala / perfecta si nu mai apar probleme nici pe sunet. Cu modul TV, selectat Elecard erau probleme.
          Oricum mersi .... este OK!
          Respecte,
          ovex
