Intrebare oscam
    Intrebare oscam
    Am un user caruia, desi i-am pus setarile de mai jos, face un trafic mare. Ce explicatie poate avea?
    uniq = 1
    group = 1
    cccmaxhops = 0
    cccreshare = 0
    cccignorereshare = 1
    Iar in log am cam asa, ca si cand ar face zapp continuu:
    2019/11/28 17:09:14 ........... c (ecm) user1 (………………. not found (241 ms) by slotsus (F/1/1/4)
    2019/11/28 17:09:14 ........... c (ecm) user1 (……………. not found (389 ms) by Slotjos(F/1/1/3)
    2019/11/28 17:09:15 ........... c (ecm) user1 (…………….. not found (386 ms) by Slotjos(F/1/1/3)
    2019/11/28 17:09:16 ........... c (ecm) user1 (……………… found (238 ms) by slotsus (L/1/1/5) - Filmbox
    2019/11/28 17:09:17 ........... c (ecm) user1 (………………found (282 ms) by slotsus (L/1/1/5) - Mooz Dance
    2019/11/28 17:09:17 ........... c (ecm) user1 (……………..found (430 ms) by slotsus (L/1/1/5) - Fine Living
    2019/11/28 17:09:17 ........... c (ecm) user1 (…………….. found (555 ms) by slotsus (L/1/1/5) - Travel Channel HD
    2019/11/28 17:09:18 ........... c (ecm) user1 (…………….. found (216 ms) by slotsus (L/1/1/5) - Realitatea TV
    2019/11/28 17:09:18 ........... c (ecm) user1 (……………….. found (398 ms) by slotsus (L/1/1/5) - Eurosport 2
    2019/11/28 17:09:19 ........... c (ecm) user1 (…………………. found (257 ms) by slotsus (L/1/1/5)
    2019/11/28 17:09:20 ........... c (ecm) user1 (……………. found (255 ms) by slotsus (L/1/1/5)
    2019/11/28 17:09:20 ........... c (ecm) user1 (…………… found (256 ms) by slotsus (L/1/1/5) - Discovery Science
    2019/11/28 17:09:21 ........... c (ecm) user1 …………….. found (257 ms) by slotsus (L/1/1/5)
    2019/11/28 17:09:22 ........... c (ecm) user1 (……………. found (398 ms) by Slotjos(L/1/1/3)
    2019/11/28 17:09:23 ........... c (ecm) user1 (………………found (405 ms) by Slotjos(L/1/1/3)
    2019/11/28 17:09:23 ........... c (ecm) user1 (………………cache2 (496 ms) by Slotjos(L/1/1/3) - B1 TV
    2019/11/28 17:09:26 ........... c (ecm) user1 (………………… found (235 ms) by slotsus (L/1/1/5) - Filmbox
    2019/11/28 17:09:27 ........... c (ecm) user1 (……………….. found (282 ms) by slotsus (L/1/1/5) - Mooz Dance
    SHALOM
    Salut
    Si eu am avut de-a face cu acest fenomen saptamina trecuta. 1000 cereri in 10 min.
    Cu setarile de mai sus nu am reusit nici eu nimic. Am adaugat acelui peer la oscam user un caid, unde i-am dat voie sa ia doar celelalte carduri, NU si acel caid care facea trafic. Dupa cum vad la tine in log, "slotsus", tot despre acelasi card era vorba si la mine.
    Poate te ajuta.
    Numai bine
      Code:
      http://www.streamboard.tv/wiki/OSCam...cignorereshare
       cccignorereshare  =  -1   #  use ignore reshare level of oscam.conf [ccc] - default
                                        =   0   #  use ignore reshare level of server
                                        =   1   #  use ignore reshare level of reader or user
      ai setat in cunostinta de cauza cccignorereshare ?
      Iti recomand sa iti verifici traficul facut de cel in cauza si sa-l atentionezi ca din punctul tau de vedere nu e ok si daca continua il stergi din serverul tau In general la orice card se cere 1 ecm la 10 sec, adica 6 ecm pe minut daca se uita din cardul tau doar cel caruia i-ai dat linia de schimb.
      In caz ca mai trage si un client de-al lui tot de la tine sau userul face zapp des atunci se schimba situatia. Insa la o simpla socoteala daca impartim 1000 ecm (cereri, cum spune @Bumbu ca are) la 10 minute obtinem 100 cereri pe minut, pai de la 6 minim daca cel cu care ai schimb ar sta calare pe cardul tau la 100 pe minut mi se pare de 10 ori mai mult. Intreaba-l pe cel cu care ai schimb daca are sugative ce au mcs prost setate scoase la produs si daca continua sa te rupa da-i o pauza pana isi seteaza el corect serverul ca tu nu il poti ajuta cu nimic, ori elimina el profitorii, ori il elimini tu pe el din serverul tau. Asta daca nu cumva iti convine situatia si iti place ce iei de la el.
      isr2002 likes this.
        Asa e, am vazut apoi dar n-am mai scris. Dar am taiat si randul ala, am lasat doar:
        uniq = 1
        group = 1
        cccmaxhops = 0
        cccreshare = 0
        si tot asa face.
        O sa il atentionez. Merci.
        .::1x::. likes this.
        SHALOM
          Daca nu se potoleste sterge-l din server ca nu ai ce pierde, exceptie de la regula este cazul in care iti convine ce iei de la el si schimbul este echitabil. Nu mai acceptati cereri peste 10.000 -15.000 ecm la 24 ore pe user, care nu se uita mai mult de maxim 5 ore pe zi la TV (adica maxim 2000 ecm daca se uita din cardul tau) si atunci daca are card local o face din gradina lui predominant, restul traficului e facut de clientii lui. Dar daca va convine si considerati schimbul echitabil, atunci e totul ok.
          isr2002 likes this.
