Buna ziua tuturor,
Am un original DM500HD cu o imagine veche si doresc sa ii fac update la o imagine mai noua gen NewNigma2 sau OpenPLI, dar fara success.
Am incercat prin web browser conform guide-ul gasit pe net, dar cind apas butonul flash...nu se intimpla nimica, fara nici un mesaj de eroare, dar nici o imagine pe care am incercat-o, nu a mers...
Am un bootloader vechi #79, si am incercat sa pun secondstage-dm500hd-84.nfi , la fel..nici o miscare...
Poate cineva sa imi dea o idee cum pot sa pun o imagine noua cu Apple Macbook?
Multumesc...
O zi placuta sa aveti!
Ce am eu acuma:
Devicename: dm500hd
Enigma Version: 2010-07-21-experimental
Image Version: Experimental 2010-07-21
Frontprozessor Version: VNone
Webinterface Version: 1.6.2
Tuner A: BCM4505 (DVB-S2)
Guide-ul pe care il folosesc pt a ma conecta la DM :
Nice Flash Tips If you use a Mac
This is fast and nice for they who have mac and want to flash their db in 3-5 min.
1. Have wi-fi network enabled on your mac
2. One network cable between lan port on mac to lan port on Dreambox (not twisted cable)
3. Go to system pref on your mac (click apple logo to the left on your screen)
4. Click tab "sharing" select internet sharing - then click share your connection from - select "wifi" - then you select "to computer using "ethernet"
a green ligt will come on when sharing is on.
see my pic from the sharing option!
6. Power down the Dreambox, either using "shutdown" and by switching off by the power switch.
Standby is not enough!
7. Connect your lan cable between DB and Mac
- (1.) Press and hold the power button.
- (2.) Switch on your Dreambox.
- (3.) Your Dreambox will get a IP from your Mac.
then open the Network Utility, you will find the utility in the utlities folder.
Then click info tab - select Ethernet, and you will see a IP 192.168.2.1, this is not the
IP you will enter in the Web Browser- the IP you need to enter will be 192.168.2.2
Then follow the instruction in your browser.
If you dont know howto flash in the web browser, just take a look at this page from dream-multimedia
This have i tested on DM500HD DM800SE
Multumesc...
Ce am eu acuma:
Devicename: dm500hd
