cron job problem
    cron job problem
    am pus un job la cron
    *3/ * * * * /etc/cron/example/osc.sh
    la etc/cron.crontab/root---am acesta informatie
    3 ba.sh ba.sh ba.sh ba.sh /etc/cron/examples/osc.sh
    proc/3 ba.sh ba.sh ba.sh ba.sh /etc/cron/examples/osc.sh
    este corecta secventa dupa 3 ? , sa afiseze Ba.sh? sau trebuie sa fie altfel?
    am primit mesaj error cron
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.386000] set wss 8 on display 1
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.386000] set sb to 3(2)
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.471000] pilot_off!
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.803000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.912000] set current avs auto aspect to 4:3
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.912000] set wss 8 on display 0
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.913000] set wss 8 on display 1
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.913000] set sb to 3(2)
    Jun 9 19:46:56 dm800 user.info kernel: [150132.356000] RCU: dropping invalid key code 4a0f441a
    Jun 9 19:46:58 dm800 user.err kernel: [150134.455000] 150434:455700000 SMCA: invalid ioctl: 0x00005407
    Jun 9 19:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 19:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    Jun 9 20:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 20:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.877000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.994000] set current avs auto aspect to 4:3
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.994000] set wss 8 on display 0
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.995000] set wss 8 on display 1
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.995000] set sb to 3(2)
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.717000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.834000] set current avs auto aspect to 4:3
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set wss 8 on display 0
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set wss 8 on display 1
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set sb to 3(2)
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.180000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set current avs auto aspect to 4:3
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set wss 8 on display 0
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set wss 8 on display 1
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.298000] set sb to 3(2)
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.711000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set current avs auto aspect to 4:3
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set wss 8 on display 0
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set wss 8 on display 1
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set sb to 3(2)
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.255000] set mute 1 (111) 0
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.295000] set input to 1
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.295000] set fb to 2(0)
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.303000] set sb to 3(0)
    Jun 9 21:33:56 dm800 user.warn kernel: [156552.327000] alps_bsbe2 is in powersave mode now
    Jun 9 21:38:31 dm800 user.info kernel: [156827.925000] RCU: dropping invalid key code 0e1e441a
    Jun 9 21:38:45 dm800 user.info kernel: [156841.286000] RCU: dropping invalid key code 02702500
    Jun 9 21:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 21:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    cum pot repara sa ruleze, corect cron--- scriptul meu
    unde este greseala?
    multumesc
    cum verific, daca cron ruleaza? ( este activ)
    unde ma uit? sa-l vad ...
    pentru istoric, verific , la log>message.
    multumesc
    efectiv nu stiu ce sa-i mai fac sa mearga.
      nu asa trebuia sa pui cumva ?
      */3 * * * * /etc/cron/example/osc.sh
        corect ce a spus raks67, ai gresit sintaxa.. probabil ca vrei sa iti ruleze scriptul la fiecare 3 minute.. deci urmeaza exemplu lui.
        cron ar trebui sa iti functioneze automat, ca sa verific dai si tu "ps ax|grep cron" ar trebui sa iti apara 2 pid-uri in lista, unu este grepul si altul este cron (/usr/sbin/cron.. sau ceva de genul). daca e acolo, inseamna ca ruleaza.
          asa am editat si eu -- dar nu a luat root bun.
          sa dau un update la cron?
          la mine este o versiune pentru 7025,....si are sytaxme diferite, la editare crontab, vizualizate la exemple.
          ii dau un update sa vedem ce descarca.
          si acum am citit help
          si spune ca se evidentiaza run - la sbin
            deci am dat update la 11:30 ( script lor de update este iup.sh-- oferit la exemple }
            apare
            Execution process;
            new crontab time will be like this:
            30 11 * * * /etc/cron/example/iup.sh
            crontab can't open "root" : No such file or directory
            dislaying new crontab :
            30 11 * * * /etc/cron /example/iup.sh
            execution finish !
            deci trebuie sa-i creez un director Root in Crontab
            asta inteleg eu
            si culmea
            am verificat etc/cron/crontab
            si are
            doua fisiere
            root................. atribut 600 si contine
            30 11 * * * /etc/cron/examples/iup.sh
            si
            cron ....... Extensie update , no atribut
            si contine
            root
            root
              am creat new director "root" dar nu l-a acceptat
              pentru rulare la 3 minute a luat ( fiind ver veche ]
              syntax
              etc/cron/exemple/osc.sh 03
              si l-a evidentiat la lista crontab
              sunt curios daca il si ruleaza. evidentiat la log>mesage
                a salvat tab
                dar nu le ruleaza
                ce alta varianta am sa execut un script , periodic?
                alt plugin?
                sau un ipk pentru cron. sa mearga pe DM , nemesis.
                ceva testat, care funtioneaza
                asta este ver 2.2- by gutemine pentru 7025
                multumesc
                  varianta cea mai buna e cu cron , dar posibil ca problema sa fie de la imagine , si eu am avut probleme cu cron pe unele imagini , nu mai stiu exact care dar au fost vreo 2 - 3 , am instalat gemini E1 pe dm500 E2 pe DM800 si merge perfect cron , numai sa ai scriptul potrivit kkkamcheck.sh
                    Cron
                    Eu folosesc img NEMESIS 2.6{ svn 107r5 } E2 DM800SE in care e instalat si pluginul 2.2 si imi functioneaza perfect pe CCcam.
                    Probabil multi stiu sa o foloseasca deja dar fac un mic tutorial ptr imaginea Nemesis:
                    Aveti aici 2 fisiere pe care trebuie sa o instalati manual cu calea:
                    Root-ul in var/etc/cron/crontabs si punem atribut 755
                    EMUSTARTER.SH in var/ script tot atribut 755
                    http://www.hotfiles.ro/download/cron...sis.rar/903871 AICI SUNT CELE 2 FISIERE
                    Intram in : MENU/PLUGIN/CRONMANAGER/LIST CRONTAB, SI TREBUIE SA VA APARA ASA:
                    */1 * * * * /bin/sh /var/script/emustarter.sh start /dev/null EU AM PUS PE 1 MINUT
                    Executam o comanda din telnet: crontab -e .
                    Dupa apasam butonul ALBASTRU urmat de ROSU START/STOP SERVICES si aici activam
                    Contab sa ruleze. Urmat sa apasati butonul verde si
                    ACTIVATE CRONTAB AT BOOT? si o punem pe YES urmat de un reboot si totul functioneaza perfect.
                    Si daca functioneaza dam comanda din telnet PS si vedem daca ruleaza..
                    Am uitat sa specific modificati in emustarter.sh versiunea de CCCcam pe care ofolositi...
                    Bafta... Testat functional 100%
                    In rest numai bine...
                    [IMG] Uploaded with ImageShack.us[/IMG]
                      probleme again
                      nu reusesc sa gasesc link-ul de download -- pe hotfiles.ro, la link-ul specificat.
                      trebuie platit, la acest site, pentru download
                      poti sa-l ridici si pe 4share.com si sa setezi contul ca public share,...
                      multumesc
                      PS:am reusit intr-un final, accesand link de servere hotfile.ro ,fileshare.ro ,girlshare.ro, din lista ,.......ok
                      am sa-l testez,...pe un script de restart Oscam
                        nu exista
                          am pus in usr{var}/script/emustarter.sh-- atribuit 755
                          si l-am rulat cu
                          TS pannel7.1>tools2>script manager
                          a confirmat ca ruleaza ok
                          idem am facut corecturi la scriptul de Oscam_Check....l-am rulat, si am primit confirmare de OK
                          mai trebuie doar sa reusesc sa pornesc cronmamager asta odata. sa ruleze el scriptul.
                          oricum m-a ajutat emustarter.sh - sa corectez scriptul meu, {avea 2 greseli in el, pe care nu le-as fi depistat niciodata}.
                          de cand am instalat acest Ipk , mi-a disparut mie Cronmanager > de la plugins> de la Meniu [ si am reinstalat un back-up imagine- dar nu a revenit la forma initiala la plugins, CRON -- acum nu mai este acolo defel ]
                          enigma2-plugin-extensions-cronmanager_0.2.2-r3_all.ipk
                          http://www.rdi-board.com/threads/143...um-se-porneste
                          eu am DM 800 simplu cu imaginea nemesis2.3 ver095r de rahmi
                          daca pornesc TS pannel >Tools-2>crons Manager> apare ecran verde- ERROARE, restart
                          intr-un final am primit confirmarea ca ruleaza Cron
                          825 root 2788s /bin/sbin/crond -c /etc/cron/crontabs
                          multumesc lui gilboa
                            mai stiti care e culmea....?
                            eu de cand sant prin acest hobby si e cevaaaaa vreme,nu am folosit niciodata script ptr emulatoare,fie ca e 3C sau oscam
                            care e problema?
                            receptoru?
                            imaginea?
                            emulatoru?
                            sau toate la un loc?
                            nu as vrea sa detaliez mai multe
                            GIGABLUE 800HD SE...GIGABLUE
                              care e problema?
                              receptoru?
                              imaginea?
                              emulatoru?
                              chiar nu vreau sa intru la amanunte, care pot sa ma depaseasca, atat pe mine cat si pe tine,...
                              ideea de baza , este ca vreau sa folosesc un anume EMU, care imi face probleme dupa 4-5 ore de functionare.
                              acest EMU il am atat pe DM 8000 cat si pe DM 800 ( in ambele parti face figuri dupa 4 ore }
                              Imaginile pe boxuri sunt diferite- deci nu este imaginea de vina.
                              Boxurile sunt super ok
                              problema este cu acest EMU, si trebuie sa rezolv resetarea lui....
                              solutia practica este job la un plugin ( cronos) sa restarteze EMU respectiv, in urma unor fedbackinfo din EMU oscamCheck(file).
                              si tot nu lucreaza Cron manager, scriptul.
                              scriptul este corect, verificat, ruleaza corect.(l-am tot modificat, pana a puscat corect)
                              daca il execut manual- primesc confirmare ca este executat corect , si afiseaza in folder .Check-- status OK.
                              dar aceasta informatie ar trebuie sa apara la fiecare minut, dupa executare de catre Cron manager din root-- dar asta nu se intampla, din pacate.
                              deci problema mea actuala este ca nu reusesc sa pornesc JOB la cronos,...! sa execute ce vreau eu.si nu stiu unde este problema ,...
                              deci poate imi recomanda cineva o arhiva sau Ipk , pentru Ver 2.2 sau mai mare a lui gutemine, sau alt autor
                              am mai gasit o versiune 1.7 de Thowi
                              Cronmanager for Dreambox 7025 1.7 by thowi from 2. January 2007
                              sunt dispus sa incerc si alt plugin - care poate executa un script-- multumesc
                              acest cron - de pe imaginea mea actuala spune ca ruleaza - dar nu se vede real nimica.
                              si Cronmanager a disparut total de la Meniu>plugin>
