hELP --How to find BOX key
    hello dear friends
    i HAve Dialoge tV packege(intelsat 12-45E) COSHIP CDVB 5110D receiver + ****** original card,
    both are married together;
    can some one give me a methode to find the box key of this unit or any relevent soft ware.
    i have CAS 2 interface,
    i need this becoz i have a dream box7020 and i need to put that card on DB to watch Dialogue tv
    any help highly appriciate,
    thanks
    Krish
    Originally posted by krish View Post
    hello dear friends
    thanks
    Krish
    The box key will be in the secret menu part
    once you get the box key you then have to convert hex serial
    do a google search
    http://www.phuket-satellite.com
      hello dear friends
      thanks
      Krish
      Irdet"2 using Boxkey ?
      Dialog TV using caid: 0631 and V5 cards i know you dont need Boxkey
      so put your Card in to the Dreambox and use CCcam
      Daeng
      10FT Dish 169° east-49°east
        i also tried with another some irdet* boxes , likes nokia dvb2000 with irdet*cam and some higher version irdet* empeded boxes....but no luck! so, it may need some box keys.......
          DialogTv no need box key
          They using very latest encorder for some old box Tuner not supported
          You can check dreambox and latest other ****** box.....
          Thanks
          http://cccam.asia
            dera sir Junaid,
            so what can i do,?my receiver is coship and Dialog original card.pls tell me how to work this card in DM7020?i need to watch these packege on my DB7020..
            thanks all
            krish
              i installed gemini 4..incccam 2.0 i found several files..pls let me know where do i put these files in DM7020.
              pls help me to put this CAID 301 to watch Dialog tv by DM7020
              thanks all
              krish
                do a google search
                What do u mean by the secret menu? I'm looking for the BOXKEY for zenega receiver working with dishtv. I want to use the dishtv card with DB. Reading at various forums/posts , it seems like the BoXKEY needs to be there in the cccam.cfg file to make the card work on Dreambox.
                Any inputs will be highly appreciated.
                Regards,
                Rajat
                  If Dialog tv is using a V5, that means its an Epilson V5.1 Card, which cannot not be used in DM, the only way you can use it is with Ir**to Cam in any other STB, which has CI Slot
                  but you have to upgrade the Cam from V1.06 to V1.12, which i have done, i am using Pehla
                  Card which is V5 Epilson, but i have upgraded my Ir**to cam and now its updating the subscription everymonth & also has speed up my STB when i switch channels.
                    Hi Everyone.
                    Could someone please tell me if it is possible to extract the BOXKEY from an ...... 2 ZETA card using a Dreambox 500S and jtag cable?
                    The smartcard and original decoder are married to each other.
                    I have tried converting the serial to HEX but that didn't help unscramble the service.
                    Thanks
                      Ir det0
                      need Cam key and Cam key data for descrambling the picture. Box key alone didn't give you any picture.
                      http://www.anishpsla.co.in
                        Thanks for your reply. I have what I believe to be the correct CAMKEY and CAMDATA values for my ...... 2 ZETA card. The problem I have is that the smartcard is married to the DSTV provided decoder so when I take that same smartcard and put it in my dreambox (DM500S), I get a green (i) but no picture or sound. I believe I need to extract the boxkey from the smartcard but haven't found anyone helpful/knowledgeable enough to confirm or deny that fact.
                        Has anyone here, post 2008, got a newer version married DSTV card to work in their dreambox?
                        Thanks
                          re
                          Thanks
                          hows south africa today - lol
                          Silly question maybe but why dont you just use your original decoder since your in south africa why would you want to put it in a dreambox decoder ?
                          Im sure the original decoder from ZA is much better
                          iLikehd
                          www.ilikehdtv.tv
                            South Africa is good thanks.
                            And to answer your question, NO!, the DSTV decoders are sluggish and buggy as hell. My Dreambox DM500s and IceCrypt HD PVR are miles faster and better in every way.
                            Back to my question, does anyone here know how to extract the boxkey from the smartcard using a Dreambox and Jtag cable?
                            OR can someone give me other options to use the married card in a Linux based decoder?
                            Thanks
                              Hi, Do I need box and RSA to run this card ?
                              2018/09/24 19:44:18 B7504B70 r caid: 0631, acs: 6.08, country code: LKA
                              2018/09/24 19:44:18 B7504B70 r providers: 4, ascii serial: 4131xxxxx,
