I am currently trying to configure a server to run several cards for me and a few friends who have all purchased a card each but I am running into problems configuring the server. I have been doing this for a few weeks now and seem to be getting nowhere fast. I have a Linux based PC running Clark Connect with 1 serial pheonix interface and 4 Infinity USB Smart readers. The cards that I am using are a Sky Italia NDS3 card, a ITV Partner Cryptoworks card, a German Premiere card in Betacrypt, a Digitalb Conax card and a Viaccess card. Now the Viaccess and Conax card are running perfeclty well. The Premiere card is working but when the server is sending keys the picture freezes briefly and then its working again for several minutes before this happens again. The Sky Italia and Cryptoworks card do not want to seem to work no matter what I try. I am using NewCS 1.67 which reads all the cards.
If somebody can look through my .XML file and tell me where I am going wrong it would be appreciated.
<?xml version="1.0?>
<newCSconfig>
<readers name="Phoenix Card Readers on Server">
<!-- <device>
<name>Phoenix on S0 (S*Y Italia)</name>
<type>phoenix</type>
<mhz>368</mhz>
<node>/dev/ttyS0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<blockC0>No</blockC0>
<boxkey>1254EB2C</boxkey>
<crypto-special>No</crypto-special>
<ipk>0000000000000000000000000000000000000000000 00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</ipk>
<ucpk>000000000000000000000000000000000000000000 00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>15000</newcamd_port>
<autosid>yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
<!-- <device>
<name>Phoenix on USB0 (Crypto Works)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB0</node>
<blockC0>Yes</blockC0>
<......-camkey>0000000000000000</......-camkey>
<......-camkey-data>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</......-camkey-data>
<carddetect>Yes</carddetect>
<newcamd_port>15010</newcamd_port>
<autosid>Yes</autosid>
</device>
<!-- <device>
<name>Phoenix on USB1 (Via-Access)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB1</node>
<parity>even</parity>
<crypto-special>Yes</crypto-special>
<newcamd_port>15020</newcamd_port>
</device>
<device>
<name>Phoenix on USB2 (Premier)</name>
<mhz>600</mhz>
<node>/dev/ttyUSB2</node>
<!-- <parity>odd</parity> -->
<!-- <reset>inverse</reset> -->
<newcamd_port>15030</newcamd_port>
</device>
<!-- <device>
<name>Phoenix on USB3 (Conax)</name>
<mhz>368</mhz>
<node>/dev/ttyUSB3</node>
<newcamd_port>15040</newcamd_port>
</device>
</readers>
<radegastserver>
<enabled>no</enabled>
<port>10001</port>
<allow>ALL
<!-- <hostname>localhost</hostname> -->
</allow>
</radegastserver>
<cache>
<!-- <emm>20</emm>
<ecm>-1</ecm>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<httpd>
<server>
<port>8080</port>
<enabled>yes</enabled>
</server>
<user>
<name>newcs</name>
<password>newcs</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<password>NewCSpwd</password>
<mode>simple</mode>
<level>internal</level>
<type>all</type>
<output>console,tcp</output>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<userfile>/tmp/users.txt</userfile>
<user>
<name>user1</name>
<password>user1</password>
<au>on</au>
<spider>off</spider>
<sidoverride>off</sidoverride>
<rate>0</rate>
</user>
<user>
<name>box1</name>
<password>box1</password>
<hostname></hostname>
<port></port>
<au>yes</au>
<rate>0</rate>
</user>
</newcamdserver>
</newCSconfig>
I also have the output file for the Premiere card located here for download if anyone would like to have a look at it.
hxxp://www.megafileupload.com/en/file/124626/NewCS-zip.html
If anyone can help it would be greatly appreciated.
Thanks in advance
Liam
