Results 1 to 3 of 3
    nuca de cocos Mentor
    Oct 2008
    SV.Romania
    Default General Satellite VA-7200 reset parola
    stie cineva cum se face reset la parola ...a pus cineva parola si nu pot sa o resetez..el a uitat-o..am inercat de la humax :Humax 5400 = Press The Menu And Go To
    Instalition Menu And Press
    Red Key & Green Key & Yellow Key & Blue
    Key & White Key And 0 .
    Now PinCode Changed To:0000
    HUMAX F1-C1 Menu - status -STB Status - ok -press
    UP button at the
    front panel - i - press the button contain ( ? ) –
    press yellow button
    ---> exit now ur receiver return to 0000
    dar nu merg !
    Member Teacher
    Mai incearca cu grija caci trebuie sa mearga.
    Menu- installation-ok-status-ok-STB status-ok then press on the following buttons-RED-GREEN-YELLOW-BLUE-WHITE- then press 0 now ur receiver is 0000 gs 7200 & SOME OTHERS HUMAX
    Menu - status -STB Status - ok -press UP button at the front panel - i - press the button contain ( ? ) – press yellow button - exit now ur receiver return to 0000 gs7001 s &hUMAX F1
    Daca tot nu merge pui din nou patch pe el si revine la 0000!
    Succes!
    Oct 2008
    Cluj-Napoca
    Resetare cod PIN la 0000 , la General Satellite GS FTA-7001S, GS CI-7101 si GS-7200. Se apasa : Menu _ OK _ Status _ OK _ Alb _ 9 _Galben _ 4 _ Rosu _ 8735 _ Verde _ apoi apare PIN Change _ (Yes)OK .Codul PIN se va schimba la 0000. Verificat pe GS FTA-7001S.
