Results 1 to 10 of 10
    Jun 2005
    BAJOUR PAKISTAN
    Default PROBLEME IN MY HUMAX 5400 HELP ME PLEASE URGENTLLY
    HI RDI FRIENDS
    THERE IS A PROBLEME IN MY HUMAX 5400 DIGITAL RECIEVER
    WHEN I ON IT APEAR; LOADER VER 2.FF "AND AFTER THAT NOT ANY DISPLAY ON TV SCREEN BUT ON THE RECIEVER SCREEN EVRY THING IS OK CHANEL UP DOWN MENU POWER EVRY THING IS WORKING WELL BUT NOT ANY DISPLAY ON THE TV SCREEN.
    PLEASE HELP ME URGENTLLY
    THANKS
    Lahore
    Did you try to upgrade with new s/w or so on?
    You may get more Help
    Fte Max 100S
    Humax IRCI-5400z
    Default 5400 Z error code rA
    I update my receiver (5400Z) but now I have the a blue screen and it is written rA on the unit itself. Impossible to swith it off or to change the channel.
    What can I do?
    Thankyou for help.
    Australia
    The software you loaded is corrupted,you just stuffed up your 5400/z.
    Follow the link that Masood posted-Hummies does not like some software that is corrupted,it freezes once u switch it on.
    I know,because it has happen to me lots of times.
    what should I do to "unfreeze" it?
    Thank you
    Rgds
    Lahore
    Quote Originally Posted by JohnSand
    Thank you
    Rgds
    Switch off the box and load the file as per your requirement by keeping the box in ON mode simulteniously.
    Fte Max 100S
    Humax IRCI-5400z
    Default I found the procedure....
    To repair the 5400Z PLUS:
    - use humax toolbox
    - disconect from power the receiver
    - change the id system in 0016.0600
    - launch Dsr9500Emu (hzu 2.0)
    - open the file clean.hdf (download on this site 5400Cleaner.zip)
    - click on upload (PC-STB)
    - switch on your unit
    - switch off the unit by the stand by button
    - disconect your receiver from power
    - change with the toolbox the ID to 0016.0601
    - open the file HIC10500_5400Z_plus
    - a message will appear on the tv: "No services are registered. Press ok to proceed service search"
    - press ok on the remote control
    - search channel in auto & in quick mode.
    Note; try to have your receiver connected to the tv to see the download progress
    Aug 2003
    Default Re: PROBLEME IN MY HUMAX 5400 HELP ME PLEASE URGENTLLY
    Quote Originally Posted by alamzeb777
    HI RDI FRIENDS
    THANKS
    Your box's UHF signal has been offset to another channel. Switch on your box and press the BLUE button on your RC, watching your box's LCD, press ARROW LEFT or RIGHT to select setting. Keep pressing until you see something on your tv screen.
    Qatar
    Default Re: I found the procedure....
    Hi Joe,
    Where did you find this Humax toolbox?
    Tks for help
    Starsat sr-x4000d super
    Lahore
    Fte Max 100S
    Humax IRCI-5400z
  1. Probleme Settings Humax 5400
    By Axell in forum RDI - Satelit
    Last Post: 29th July 2006, 03:10
  2. Humax 5400, Zeta Cam Blue si Max Tv probleme !!!
    By Bumbu in forum SD Receivers
    Last Post: 30th December 2005, 19:02
  3. HUMAX 5400
    Last Post: 7th November 2005, 17:15
  4. Probleme cu Humi 5400!
    By the the in forum RDI - Satelit
    Last Post: 15th May 2005, 10:10
  5. Humax 5400 probleme
    By AndreiD in forum SD Receivers
    Last Post: 2nd May 2005, 15:23
