Results 1 to 15 of 22
    Sep 2003
    BRASOV
    Default dbox2 debug mode problem [ rezolvat]!!!!
    log win xp
    IP-Source: 192.168.5.3 - IP-Destination: 192.168.5.7
    ICMP
    ***Adapter Desc: Realtek RTL8029(AS) Ethernet Adapt
    ***MAC address: 52:54:05:FD:8A:A7 Local IP: 192.168.5.3 (via Packet-Driver #3)
    ***BootP server started... Port 67
    ***TFTP server started... Port 69
    ICMP
    ICMP
    BootP> Request from 00:50:9C:1B:45:E1 (assuming that this is DBox).
    BootP> Answer sent!
    TFTP> Started TFTP-Transfer for "C:\MINIFLASH\kernel\os"...
    TFTP> Transfer finished, sent 2444 blocks
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    cand dau comanda >help zice couldn't coonect to DBOX! (Timeout...?)
    cand este conectat la bootmanager scrie tot timpul reset,iar cand il deconectez scrie kein system pe lcd box.
    log win 98
    ***MAC address: 52:54:05:FD:8A:A7 Local IP: 192.168.5.3 (via Packet-Driver #1)
    BootP> Answer sent!
    TFTP> Started TFTP-Transfer for "C:\MINIFLASH\KERNEL\Os"...
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    si nu incarca nimic in box
    are cineva vreo idee.cu pachetul asta miniflash am mai pus in debug mode dbox2.problema cred ca este hardware.
    350 kg de scule!
    Mi se rupe Expert
    da , de banuit ca-i un 2xi cu Bmon1.0.
    asta te-ar ajuta http://www.dietmar-h.net/mhc_debugn2xi.html
    bafta
    Sep 2003
    BRASOV
    Quote Originally Posted by badboy
    bafta
    exact. dar din pacate nu stiu germana.
    350 kg de scule!
    Sep 2003
    BRASOV
    in rsh client mi-a dat urmat mesaj,dupa ce am facut ca si mai sus in linkul care lai postat.
    *** Achtung: RSH ist bei fast allen Linux-Images nicht konfiguriert/aktiviert!
    *** RSH wird also nur funktionieren, falls ihr euren Linux-Kernel gepatcht habt.
    iar logoul.....
    ***Adapter Desc: Realtek RTL8029(AS)-based Ethernet Adapter (Generic) (via IpHlpApi #0)
    BootP> Created dynamic ARP entry for DBoxIP 192.168.5.7 with MAC 00:50:9C:1B:45:E1
    BootP> Answer sent!
    TFTP> Started TFTP-Transfer for "C:\dbox\ppcboot"...
    TFTP> Transfer finished, sent 157 blocks
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    350 kg de scule!
    Sep 2003
    BRASOV
    acum urmatorul mesaj
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    BootP> Answer sent!
    350 kg de scule!
    Procedura numai pentru Nokia 2xIntel bmon1.0
    Metoda aceasta nu este pentru Sagem.
    Metoda aceasta nu este pentru Philips.
    Metoda aceasta nu este Nokia 2 x AMD
    Metoda aceasta nu este pentru Nokia 2 x Intel mit Bmon1.2.
    Aceasta metoda este numai pentru Nokia mit 2x Intel-flash und Bmon 1.0
    La fiecare alt Box se va strica boatloaderul daca folositi aceasta metoda.Dupa care nu veti mai putea folosi Boxul si va trebuii dus la reparat.
    Apasati tasta sageata in sus in combinatie cu tasta Standby in acelasi timp (Reset) dupa care lasati tastaStandby.Tasta tasta sageata in sus mai ramane putin apasat pina cind va apare pe LCD un sir de numere care arata cam asa : : 01DD10081 161608
    Folositi aceasta metoda numai in cazul in care numaru 10 apare exact in aceeasi pozitie ca mai sus.
    Atentie la faptul ca acest tip de Boxe nu au predica de scris.
    Metoda de scriere:
    Comenzile pe care trebuie sa le scrietzi sint in bold scrise.
    Tastele care trebuie folosite sint scrise asa : [Enter]
    Pregatiri
    Boxul trebuie sa fie legat la PC printr-un cablu Nullmodem si un cablu Network.
    Toate serverele necesare le gasiti in Dbox2-Bootmanager
    In continuare aveti nevoie de ppcboot ( fara terminatie de ex. .txt) care trebuie sa il introduceti in C:\dbox\.
    Configuratia la Bootmanager:
    RARP-Server starten Aus
    BootP/Tftp-Server starten Ein
    Bootfile für die Dbox C:\dbox\ppcboot
    NFS-Server starten Aus
    COM-Port öffnen Ein
    Verbindungsgeschwindigkeit 9600
    Procedura
    Porniti Bootmanager dupa care Dbox.
    Boxul incarca ppcboot si face , din cauza ca nu are signatura, un Reset.
    Cind va apare pe LCD RESET , apasati tasta tasta sageata in sus, pina va apare in LCD numaru amintit mai sus.
    Uniti punctele pentru Flashreset , pina va apar cele 5 bare dupa care puteti lasa contactul.
    Danach könnt ihr die Kontakte wieder lösen.
    Atentie mare la tiparirea comenzilor.O greseala poate avea urmari grave.
    Achtet bei allen Befehlen sehr sorgfältig auf die korrekte Eingabe!
    Ein Vertipper kann aus der Box einen extravaganten Briefbeschwerer machen.
    Tipariti in COM TERMINAL :
    icache [Enter] .
    Veti primi un raspuns :: icache is on .
    Dupa care tipariti :
    chorus 800000 [Enter].
    ppcboot porneste si primiti raspunsurile de pornire.
    Copiati primul sectoral flashului in RAM:
    cp 10000000 01000000 1000 [ENTER]
    Editati adresa 0x10000944, acolo este scrisa variabila productului..
    nm 01000944 [ENTER]
    Adressa resetata la 0:
    01000944: ffffffff ? 00000000 [ENTER]
    Parasirea modului de editare:
    01000944: 00000000 ? [ESC] [ENTER]
    Die Protection des 1. Flash-Sectors aufheben:
    Ridicarea protectiei in sectorul 1 din flash
    prot off 1:0 [ENTER]
    RAM-ul schimbat copiat in primul Sektor:
    cp 01000000 10000000 1000 [ENTER]
    Piedica de scris trebuie sa fie deja ridicata daca a existat vreodata.
    Acum puteti reseta Boxul cu comanda : go 10000100 [Enter] .
    Bafta GOGI.
    PS: Salute badboy
    Sep 2003
    BRASOV
    da este bmon 1 si am sa incerc la noapte procedura.
    merci! si sper sa reusesc
    350 kg de scule!
    Mi se rupe Expert
    merge sigur , am avut si eu o data un box , exact cu problemele care le ai tu acum , iar acum e bine mersi.
    @Mehiyou
    cind vii la o bere ?
    salute
    @badboy
    e rindu tau .... e pregatita deja
    Apr 2004
    Austria,Sgb/Tm
    Sep 2003
    BRASOV
    icache [ENTER]
    usage: icache [on | off]
    chorus 8000000 [ENTER]
    chorus 0x10020000
    elfCopy failed: 16
    mai departe imi prind urechili.
    am incercat pe win xp si pe 98 la fel pe laptop win 98 si win xp am ppcboot fara terminatie text,am facut exact cum ai zis,am construit cabluri noi exact ca in linkul de mai sus cu toate ca aveam dar sa fiu f sigur.numai cu cineva care sa mai lovit de asa ceva pot sa o scot la capat,daca nu il trimit la cluj la mesterul @dongle!
    350 kg de scule!
    @gogi
    elfCopy failed: 16
    ppcboot nu porneste din cauza unei probleme de comunicatie...
    cam aceeasi problema ca si la : "boot net failed"
    daca cumva ai un firewall instalat sau xp sp2 , cite-o data mai fac probleme si programele de antivirus deinstaleazale ... nu ajunge numai sa le deactivezi .
    Din pacate sint azi si miine in deplasare nu pot sa intru pe chat...incerca inca o data si daca nu merge ne vedem duminica pe chat si o rezolvam.
    @Koondor
    nu am mai pus pozele inca o data pentru ca sint linkuri pentru fiecare receiver in howto-urile pentru dbox mai sus cu citeva rinduri ....
    Bafta
    Mi se rupe Expert
    da , icache [on | off]
    tre sa fie ON , iar asta tre sa-ti apara daca ai facut Flashreset la momentul potrivit , iar boxul a ramas cu 5 linii in display.
    deci , dupa ce s-a oprit boxul cu 5 linii pe display , deabia atunci desfaci legatura dintre PIN si GND.
    salute
    Sep 2003
    BRASOV
    exact asa am facut,dar degeaba am incercat si pe win 98 care nu are instalat nici un antivirus,nici nu iese pe net.este un hdd de 8 gb,win 98 numai cu software de sat,jtaguri si alte chesti legatede sat,il folosesc numai ptru asa ceva,dar degeaba.acelasi mesaj pe laptop si unitate[email protected] am facut exact asa:am dat drumu la bootmanager am bagat boxu in priza,am apasat tasta cu sageata in sus,au aparut nrele de mai sus cu diferenta ca in loc de 16/16 era 32.am facut scurtul pana a ramas blocat cu cele 5 lini si numerele,am inceput sa scriu comenzile.
    dar acelasi mesaj de mai sus imi dadea peste tot.UNDE AM GRESIT?
    am vb oricum cu @dongle la tel si maine sau luni il pun la posta.
    mi-e ca iam imbulinat bootloaderul
    350 kg de scule!
    Sep 2003
    BRASOV
    este trimis la doctor sa-i gaseasca bubita
    topic inchis
    350 kg de scule!
  1. Rezolvat
    By NaSiS in forum DTH & Cable-Romania
    Last Post: 17th December 2006, 22:40
  2. GboxFree DOWN ??? [rezolvat]
    By chooleen in forum RDI - Satelit
    Last Post: 11th September 2006, 06:40
  3. Dbox2 cpu problem
    By costello_ in forum DREAMBOX
    Last Post: 7th November 2005, 11:45
  4. Dreamweaver? Design Mode VS Code Mode
    By majidpsh in forum RDI - English
    Last Post: 8th October 2005, 19:24
  5. Biss - dbox2 (rezolvat!)
    By bono in forum DREAMBOX
    Last Post: 8th September 2005, 19:17
