    pakistan
    Default one dish antenna four receivers
    hello friends,
    i have one c band dish antenna, and i want to display four receivers
    on it! how can i do it?
    when i connect the many receivers then most of the channals are
    become stilling.
    i know there is c band LNB in the market which has 3,4 output
    but i have single output LNB,
    ok?
    rafay
    ZAFARJOIA Teacher
    Aug 2004
    PAKISTAN
    Default MULTI RECEIVERS
    HELLO DEAR,
    YOU CAN NOT USE MORE THAN ONE RECEIVER WITH H/V
    SWITCHING LNB. YOU NEED SINGLE SOLUTION LNB WHICH WORKS
    WITH FREQUENCY 5150 OR 5750 .
    BECAUSE VOLTAGE SWITCHED H/V LNB ONE SIDE WORK IN ONE TIME
    HOR OR VER ON ALL RECEIVER.
    OR U NEED MULTY OUTPUT LNB.
    alanpaladka
    Default Re: one dish antenna four receivers
    Quote Originally Posted by rafay
    hello friends,
    become stilling.
    ok?
    rafay
    Use channel PD(LNB Splitter). It is used in Cable TV's to connect many receivers to a single LNB.
    pakistan
    Default Re: MULTI RECEIVERS
    Quote Originally Posted by zafarjoia
    HELLO DEAR,
    from where will i be able to buy that LNB
    which can be do my work?
    and what is its name.
    Sep 2004
    SunshineState,Australia
    Default Reply-1 Dish = 4 receivers
    I have a 2.3 Sate. Dish with 4 Satellite Digital Receivers connect to it.
    My Dish is fixed to AS3.
    But I have a 4 way splitter, which turns my Dish LNB signal via the 4 way splitter into four output signals to each receiver.
    No. 1 to my bedroom.
    No.2 to my Mum's room.
    No.3 to the Dining/Kitchen living-Family area.
    No. 4 to my Lounge-guest area.
    ps. Splitters are available in 2ways, 4 ways .in ever TV shop.
    (Thanks to W.in 2000 for showing me this method.)
    Thanks for reading my mail.
    JPS-Australia
    ZAFARJOIA Teacher
    Aug 2004
    PAKISTAN
    Default more receiers
    DEAR YOU CAN WATCH ONLY VER OR HOR IN ONE TIME
    ON ALL RECEIVERS BY USING POWERPASS SPLITTER.
    YOU HAVE TO USE SINGLE SOLUTION LNB TO WATCH BOTH
    POLARITY HORIZONTAL & VERTICAL ON ANY RECEIVER
    WHILE YOU ARE USING MANY RECEIVERS.
    CABLE OPERATORS USE DUAL FEEDHORN FOR 2 LNB
    HOR AND VER SEPARATELY OR SINGLE SOLUTION.
    U CAN BUY IT FROM HALL ROAD. NEW PIONEER ELECTRONICS.
    FOR DETAIL INFORMATION CALL ME 0404007129.
    Australia
    It is true that using a splitter disables one polarity or the other.
    Follow zafarjoia for advice. You must use a twin output LNB with suitable "Multiswitch"
  1. Satellite Antenna Alignment
    By fansat03 in forum RDI - Satelit
    Last Post: 30th October 2006, 17:49
  2. Satellite Antenna Alignment
    By msalman in forum RDI - English
    Last Post: 17th July 2006, 17:23
  3. sharing dish and single LNBs in 2 receivers???
    By otaner2k6 in forum RDI - English
    Last Post: 17th May 2006, 20:57
  4. antenna 1 on w2
    By dom in forum RDI - English
    Last Post: 14th August 2005, 17:26
