Results 1 to 6 of 6
    Banned Teacher
    Sep 2004
    karachi
    Default fiber optic cable
    hi friends any body tell me i want use lnb to satellite reciever fiber optic cable for best signal quality r this possible r any good sagetion how i get better power full signal from lnb because i check on hotbird i use small size cable i recieve 60% signal but i come in my room with 20 meters cable i recieve only 45% signal what is problem please put light on this topic and give me suggetions to recieve good quality signal thanks
    Fibre optic cable from sat receiver to LNB is not possble. Use RG11 cable instead.
    Jul 2005
    india
    good idea, no way......
    back in the days of my VHF/UHF radio days, i use RG8 coaxial cable for less loss on the signal quality of both RX/TX signals. this can be applied also to lnbs. RG8 can tolerate up to 300 meters before you suffer significant signal loss. or otherwise, put a line amplifier after the diseqc switch.
    (anybody is free to rebuke the use of RG8 for lnb lines).
    RG8 has 50 ohms impedance and used for radio communications, but for video broadcast you must use 75 ohms.
    alanpaladka
    Default Re: fiber optic cable
    Quote Originally Posted by geosaleem
    Use a RG8 "TFC" or "Finolex" Cable. Both these have very low resistance to the signal flow.
  1. CABLE-138/5 NULL MODEM CABLE 9F/9F 5M
    By romeoX in forum RDI - Satelit
    Last Post: 14th January 2006, 08:42
  2. I-Cable
    By da_sh2000 in forum RDI - English
    Last Post: 4th January 2006, 08:18
  3. why zee gone from cable tv
    By geosaleem in forum RDI - English
    Last Post: 27th September 2005, 11:01
  4. NOU:Uni Cable Lnb
    By nirolf in forum RDI - Satelit
    Last Post: 27th June 2005, 11:31
  5. HK Cable on 138
    By ssunny in forum RDI - English
    Last Post: 3rd June 2005, 17:54
