    PAKISTAN
    Default Card Splitter Card Sharing Hub for irdeto2,Viaccess2 .......
    Card Splitter is an Irdeto2 , Viaccess2 and Seca Mediaguard Sharing hub, With this Card Splitter you can share one original smart card between all your receivers ( 4, 8 , 16 receivers or more by cascade system ) and the card splitter will connect to the digital receivers by the slave which will be insert inside the receivers cam and its work as the original card inside your receiver, this solution is useful when you had more than 1 receiver in your home but you didn't want to pay monthly fee for extra card.
    CARD SPLITTER CS16-PRO contain 1 master Unit + 16 slaves which allow you to connect 16 digital receivers to 1 smart card
    Features:-
    Host device clock auto range: 2.5 MHz - 8 MHz.
    1000 meter phone cable (reference 12 ohm per 100 m)
    Each host device can switched on/off without disturbing other ports operation
    Auto re-start after power failure
    Stand alone operation, manages the smart card itself
    Optical isolated and 'breakable' slave units to use 5 wire flat cable
    Very fast master <-> slave communication (>30 Kbytes/s)
    Internal managed 32 entries cache to shorten reply time
    Cascaded operation possible
    the price of the card splitter is:-
    CS4-PRO = connect with 4 receivers ( 300US$ )
    CS8-PRO = connect with 8 receivers ( 500US$ )
    CS16-PRO = connect with 16 receivers ( 700US$ )
    For more Information Visit GLOSAT Website :- http://www.glosat.com/index.htm
    SATELLITE GURU Expert
    Your prices listed are a rip off.
    I can get a splitter for Irdeto2 Viaccess Seca and 5 chipsets with 14 ports for less than US$ 200 Each chip card can be bought for around 25US$.
    PAKISTAN
    irdeto2engineer this is not my prices..
    i just want to introduce a Card Sharing HUB of GLOSAT
    maybe some people dont know about this hub.
    this is very good device for card users
    Bye Take care.
    Card splitters are well known here on RDI.
    It's old technology but works well.
    Dec 2010
    Default glosat
    Pls anyone pm me where can i get glosat cardsharing receiver
  1. Card Splitter 8-12 ??
    By cogil in forum RDI - English
    Last Post: 23rd August 2006, 01:27
  2. Wireless Card Splitter
    By gigelsat in forum RDI - Satelit
    Last Post: 28th February 2006, 10:43
  3. Cumpar card splitter...
    By cristi in forum Shop
    Last Post: 14th January 2006, 21:59
  4. Unde gasesc card splitter ?
    Last Post: 28th November 2005, 22:16
  5. cumpar card splitter ptr co sau via
    By cristi.111 in forum Shop
    Last Post: 26th September 2005, 00:09
