Results 1 to 9 of 9
    Multi Banned User Expert
    Default digi pro exel tv - satelit finder
    cunoaste cineva scula ? pareri ?
    http://www.satcatcher.com/digipro_excel_tv
    -=AS=-
    Sembox DSM 2009
    The digital satellite finder Sembox DSM 2009, with an ultra-light weight of less than one kg, is super easy to transport and thanks to a digital Sembox when DSM 2009 neck strap attached to the roof is not an obstacle.
    The Sembox DSM 2009 meter shows not only signal strength quality, but you still during an installation first channel images on the TFT-LCD screen. Among other things, is a signal to noise ratio in the digital satellite finder Sembox DSM 2009, numerically and in bars, it also helps with acoustic signals when adjusting the satellite antenna.
    The satellite meter Sembox DSM 2009 can be easily - easily programmed by the user. 13 V, 18 V, 22 kHz and signal-detection lights directly under the TFT LCD screen, also an automatic calculation of position Horizontal / Vertical.
    * Input Frequency 950~2150MHz
    * Input Impedance 75
    * Input Level -65~ -25dBm
    * USALS supported
    * BER, S/N, FEC Indication, angle Calculation
    * Sound Alarm & Light alarm when waek signal locked
    * Auto search, blind search, NIT search, manual search supported
    * Shortcut F1 to roof mode (bigger signal bar)
    * Mini size, 102mm x 34mm x 180mm
    * DiSEqC 1.0 DiSEqC 1.1 and DiSEqC 1.2, Auto DiSEqC Supported
    * Global satellite list & multi language Technical Facts DSM2009 - Digital Satellite Meter with Digital Spectrum
    * Digital meter for signal strength (in numerical value and picture)
    * Outdoor menu mode for installation outside
    * 22K Indicated by light
    * 3.5 Inch high definition TFT LCD screen which can play channels
    * AV-IN (by RCA) fuction for testing STB, camera, etc.
    * LI-ION battery (2200mA), last 6 hours, fast change (2 to 3 hours)
    * RCU optional
    * RCA output for TV
    Zic ca e mai tentanta varianta asta... urmeaza sa-l achizitionez... am auzit cateva laude.
    La ce pret ajunge cel pe care ai pus ochii ?
    nu am ajuns inca la pret. la cit e al tau ?
    -=AS=-
    398 euro ...nu vad sa fie cu mult mai ieftin cel din link-ul tau, dar de curioziate ce pret are ?
    habar n-am cit costa !
    Dec 2002
    piiiii bloc
    Excel tv-ul e vreo 500 si ceva de lire.Englezesti
    Semboxul e facut de rusi au acelasi pcb cu ceva versiuni nemtesti......softul cam slabut...
    Ca sfat...ia un trimax sm2500 (gasesti la 1990 la noi in tara).Merge binisor...stie autofec are si analizator spectral....etc
    Mi-am luat de vreo sapt si sunt supermultumit .Nu mi-a venit sa cred ca cica tine bateria 4 ore.Si chiar tine )
    http://www.trimaxmeters.com/index.html
    iphone unlocker Expert
    Costa Tropical(ESPAŃA)
    Nobody is Perfect
    I am Nobody
    -=AS=-
    Quote Originally Posted by ghettoman View Post
    Ce stii despre Sembox, ai avut vreo experinta ?
    espańa
    Quote Originally Posted by -=AS=- View Post
    la www,padredefamilia.com e cu 329 taxe incluse
    si io am auzit laude despre el .
    Fiti Aliati
    Dreambox
