    Mar 2003
    Palau
    Default about cline active to peer?
    assalam o alikum
    forum members plz guide me how do i know if my cline is active to a friend or peer although its cline is active to me i can watch channels through him but he cant see unless my cline is active to him i have got both accounts on no-ip.info and on dyndns and previously i was sharing on echolink only gbox now i have got dm 500-s and i want to know cccam setting to send my active cline and even i set my configuration in my ptcl modem zyxel p-600 series their i enter dm ip and my account port of gbox currently i am abel to connect with my gbox and cccam but my cccam cline is not showing active to others if i send in different clints is their some thing wrong doing and yes even my idyan is also succesfuly update showing plz guide me ?
    there must be something wrong with your port forwarding from the router. check that.
    you cannot connect to him unless your dyndns or no-ip data are updated if he put the filter:
    f: user name 2 0 0 { 0:0:2 } { } { } { yourdyndnsaddresshere }
    Mar 2003
    Palau
    ok dear but why i am able to have sharing in both ccam and gbox but the main error is my cline is not showing active to peers is their image problem or their is setting in network of modem in lan,wan or nat or their is setting in port forwarding like this currently
    # Active ServiceName StartPort EndPort Server IP Address Modify
    1 emule-UDP 6193 6193 192.168. 1. 33
    what i have to change in it or their is setting in script of imag currently i am using kgd 2.10
    no, you are not sharing if they cannot connect to you.
    please specify what you have done exactly. are you using both gbox and cccam on the same machine?
    the fact that they cannot connect to you means there is something wrong with your configuration, either in the cfg or your routers.
    Mar 2003
    Palau
    dear brother currently i am sharing on both emulators and on gbox i am geting hello and from but on cccam i can see peers active but on my friends side i am not active what and where is wrong ?
    Feb 2009
    bahi aap VPTCL Wireless use kar rhy ho kya?
    Mar 2003
    Palau
    no dear i am using ptcl dsl 512
