Results 1 to 6 of 6
    Apr 2004
    Default Problem with V-Polarity (Cband)
    I tunned a stallite dish towards PAKSAT1 (38 degree east). I am getting all channels with H-polarity. There comes no signal for V-polarity channels. What is suspected?.
    May 2005
    As per my knowledge, you have to use simple cband LNB not digital/dual LNB. Secondly scan vertical channels by selecting another sat slot with LNB config. 5150. Hopefully you will get vertical channels also. Good luck.
    Apr 2004
    Dear Abdul Ghafar
    Can you please explain further regarding second option:-
    My PAKSAT1 is on LNB-4, all other LNB positions (1,2,3) are occupied. So 'Selecting another Sat slot' means I have to select satellite other than PAKSAT1 on LNB-4 position and search for V-channel.
    If you means someting else please explain.
    21.95° N 97.06° E
    Quote Originally Posted by mtiqbal View Post
    Dear Abdul Ghafar
    Firstly , U need to check ur LNB is working both polarity or not . Just try to tune ur LNB to Receiver directly and don't use ur DiseqC. Otherwise , try to change the port eg: to port 3,2,1 . If both polarity will working When u connect directly to Lnb & receiver then ur LNB is ok but DiseqC switch has a problem.
    Hope it'll help u anyway.
    " 李俊明 Born To Help People "
    May 2005
    Dear Abdul Ghafar
    Yes you have to select one more satellite other than PAKSAT1 on LNB-4 position and search for V-channel, if you have this option in your receiver.
    Africa-Kenya-Nbi
    Just as yan mentions do a direct tuning to receiver
    without Diseqc, that will help eliminate the LNB, Receiver settings and skew on LNB setting.
    Else use a satellite meter for v transponders - go advance.
