Results 1 to 11 of 11
    Jun 2007
    Default Symbol rate 40700 problem
    I use a single LNB to get both NSS6 (95E) & Insat 4B (93.5E). Since long time I had this problem that my Dreambox won't lock on NSS6 Transponders where Symbol Rate is 40700.
    But today when I was in a Insat 4B channel (Sun DTH) I just try to do a mannual scanning my giving 11037 V 40700 freq. Suddenly the TP was locked & all the channels were picked. Then I tried the other 4 TPs where SR is 40700 & all the channels got picked.
    But then I went to a channel newly picked but the TP not locked this time. When I checked all the newly scanned channels won't locked.
    Anyone think what the problem can be?
    Default Do factory default
    Dear try to factory default , may be it will be ok.
    Latest Transponder updates
    BE HAPPY AND MAKE HAPPY
    Jun 2007
    I did a factory reset. But it did not fix the problem.
    Any other way to get the things working?
    Default download software
    Ur final soultion is to upload new or any software for ur particular stb ,
    Jun 2007
    While in a Thaicom 5 Ku band TP (12656 H 30000) when I goto Mannual search & enter NSS6 TP 11037 H 40700 here's how it locked (pls see the attachment)
    It also allow me to scan the TP & it even get the channel list of that TP.
    But then when I go to one of the channel newly scanned, It won't lock.
    Pls help.
    Default why u lock it
    why do u lock the channels.
    Jun 2007
    Lock the channel means the receiver pick (tune) the channel.
    Default press start
    Quote Originally Posted by dimu1234 View Post
    Dear bring ur blue belt on start and then scan it with pressing start,
    Jun 2007
    What you mean by
    "bring ur blue belt on start"
    Default pointer
    bring ur pointer on start and scan channels. and keep off ur lock point which is on. then watch it.
    Jun 2007
    Tried but no luck.
