    Mar 2003
    Palau
    Default 8 way diseqc switch and dreambox 500s help?
    dear
    respect members how do i use 8 way diseqc switch for my dreambox 500-s i have eight lnbs now what are the setting in dreambox thanks
    Jul 2006
    Pakistan
    Dear DuugDuug
    Call here you will get the solution
    00923324945688
    [email protected]
    Umair Anees
    Abdul-Aziz
    Quote Originally Posted by Abdul Aziz View Post
    Dear DuugDuug
    00923324945688
    [email protected]
    Umair Anees
    hehehe, yeah... let him call you up from Palau to Pakistan....
    look around at the Non-standard user defined settings and you will find your answer.
    Default Diseq settings
    In the satellite configuration
    after u select the lnb number option
    go to next page
    select diseq ver 1.1
    select all options to none
    and in the last uncommitted switch put the corresponding lnb number
    Jun 2007
    1st Select the Diseq type 1.1
    2 Select the Switch mode to 1 to 8( there are 1 to 16 )
    3 Select the Uncomitted option
    for more info I will post the snaps today evening.
    Cheers
    too much spoonfeeding is not good sometimes.
    lnb0 disecq 1.1-input 1
    lnb1 disecq 1.1-input 2
    lnb2 disecq 1.1-input 3
    lnb3 disecq 1.1-input 4
    lnb4 disecq 1.1-input 5
    lnb5 disecq 1.1-input 6
    lnb6 disecq 1.1-input 7
    lnb7 disecq 1.1-input 8
    or
    lnb0 disecq 1.1 comitted A uncommitted 1
    lnb1 disecq 1.1 comitted B uncommitted 1
    lnb2 disecq 1.1 comitted C uncommitted 1
    lnb3 disecq 1.1 comitted D uncommitted 1
    lnb4 disecq 1.1 comitted A uncommitted 2
    lnb5 disecq 1.1 comitted B uncommitted 2
    lnb6 disecq 1.1 comitted C uncommitted 2
    lnb7 disecq 1.1 comitted D uncommitted 2
    Mar 2003
    Palau
    dear
    members thanks to reply i solved the problem and got all seven setellites
    Feb 2009
    Saudi Arabia-The Kingdom
    Well, enjoy your favorite channels in all 7 satellites ( that's plenty I think!).
    dreambox forever
