Results 1 to 2 of 2
    Aug 2004
    Default TFC Signal Split
    What is the best way to split signal of TFC from TFC decoder to other rooms of the apartment. The TFC decoder does not have RF out only RF in but have Audio Video out.
    alanpaladka
    I suggest you to use a ACM(Adjacent Channel Modulator) of Channel 2 which is used in cable TV systems. Because in other options, if number of TV's increases or distance increases, you will not get a good signal quality and it doesn't have a option to increase signal. But if u use ACM, you can increase the signal quality by using a simple Broadband Amplifier. These equipments doesn't costs much. This is very simple and easy way to distribute signal.
  1. Dream non-split files !
    By CristianTM in forum DREAMBOX
    Last Post: 26th January 2006, 12:47
  2. .ts split
    By spoealar in forum DVD - DIVX - HIFI
    Last Post: 23rd December 2005, 20:43
  3. .ts - split
    By spoealar in forum RDI - Satelit
    Last Post: 6th November 2005, 23:35
  4. Split hdtv avi files?
    By jerkoffsky in forum DVD - DIVX - HIFI
    Last Post: 21st June 2004, 15:38
  5. split DVD?
    By maxx in forum DVD - DIVX - HIFI
    Last Post: 26th May 2004, 03:04
