    Timisoara
    Default progdvb probleme...
    am instalat progdvb, skyview si dreambox........
    skyview si dreambox merg f. bine inschimb progdvb imi merge sacadat, iar la schimbarea canalului dureAaza foarte mult sau se blocheaza.......
    am instalat progdvb 4.38.2,filtrele elecard, ss2, drivere 4.22, amd 1700+, 256mb ram.......
    dupa ce rulez program. o saptamana folderul cu progdvb imi arata ca are 2gb.........
    va rog ajutati-ma, pt. ca am vazut multi fol. acest program.......
    va multumesc anticipat........
    Wild West
    Instaleazal din nou si nu bifa buffer-ul.Iti apar 2G in folder-ul ProgDVB-ul deoarece functioneaza buffer-ul si inregistreaza cam tot ce prinde. Pt cealalta problema ar putea fi de la filtre. Ai instalat patch-ul elecard pt filtre?
    Timisoara
    nu stiu daca am instalat pach-ul..........
    de unde il iau?
    Jun 2003
    Pt patch vezi:
    http://home.rskoming.net/~sinisav/programi.html
    Daca nu merge mai cauta cu Google
  1. probleme progdvb
    By ciortuz in forum Placi DVB
    Last Post: 29th June 2006, 10:21
  2. Probleme ProgDVB 4.72.8
    By Victor64 in forum Placi DVB
    Last Post: 13th June 2006, 17:59
  3. Probleme cu progdvb
    By gavrild in forum Placi DVB
    Last Post: 23rd February 2006, 16:12
  4. progdvb probleme
    By olimpicSAT in forum Placi DVB
    Last Post: 24th June 2005, 11:00
  5. probleme cu progdvb...help...
    By ovidiumarius in forum Placi DVB
    Last Post: 15th September 2003, 16:38
