Results 1 to 15 of 16
Thread: Please Help Me
    21.95° N 97.06° E
    Default Please Help Me
    Hi friends , I want to change my computer IP Address.Can i change this address or not ? If we can do this , plz. teach me how to change the address.
    @Dear Sir BBB ,
    I need ur help.
    Regards.
    " 李俊明 Born To Help People "
    Jul 2006
    thailand
    @Dear Sir BBB ,
    I need ur help.
    are you vista or xp
    Regards.
    are you vista or xp
    Oct 2007
    u need software like hide my ip that will show different ip than what u have or u can do some search for creating static ip.
    which IP address?
    if you meant your ISP IP address, then i suggest you use tor/vidalia bundle as it has unlimited number of proxy lists.
    if you meant your own LAN IP, then go to network connections, properties of your connection and modify the TCP/IP properties.
    Ghost Teacher
    IceLand
    around IP Nr to change you must into your modem,Router in the RESET hole to press and 1 minute wait
    21.95° N 97.06° E
    Thanks alot brothers for ur support.Let me tell u my problem .... last Wednesday I've registered an account on one of the pay site.When account has been activated they said that only one computer can use their account which was using to register their account.I've registered my account with my PC but i wanna use on both my lappino and pc.
    So , i think that website can only save my computer IP address.Not my ISP IP address or LAN IP address. coz. I've tried to test it by using the same modem on both computer but without success.So, I've check on my both computer with command prompt ( ipconfig/all ) and one IP address is different.I think if I can change that pc's IP address then i can access to that site with both computer.
    I need ur advise urgently n really appreciate my friends reply.
    Regards.
    Yan.
    nopes, when you login... you get cookies. it will identify you from that cookie.
    21.95° N 97.06° E
    Thx. BBB , How can i do to get it on another PC n plz. teach me how to do .
    Regards.
    21.95° N 97.06° E
    Dear BBB , can i copy that cookies and can use on another pc ?
    Jed, KSA
    I think you have to use static ip that same ip on both by manually configuring. also shut down the computer and then put the ip of that comp in your laptop and log in. If succesfull it will set the cookies and then you can use both together but will keep getting message of IP conflict as both will have same IP. This is just a suggestion.
    you cannot use the same IP on a single network, there will be conflicts as mentioned.
    as for cookies being copied... i don't think so.
    Jan 2007
    Malaysia
    if the site you mentioned activated local activex applications then just
    change your pc MAC address and that will get working again
    21.95° N 97.06° E
    Yes BBB , i can paste 'cookies' on local folder but didn't success.By the way how can i change my Mac address ? Plz. teach me brother bok.
    Regards.
    21.95° N 97.06° E
    Quote Originally Posted by shahjees View Post
    Thx. bro how can i change this Mac ?
    Jan 2008
    download this application to change your PC MAC address, when your account expires simply re-change new MAC address
    http://rapidshare.com/files/19014056...anger.rar.html
