Results 1 to 6 of 6
    Aug 2004
    Default freezing problem
    Hello All, I need advise on how I can minimize or eliminate this freezing problem when using dvbProg. After 1 hour or so of smooth viewing and so with recording, the display pictures goes to a bad quality, the motion slows down and then goes freeze. Any advise to solve this problem? Im using P4 3.0Ghz 1024RAM and 128MB VGA NVIDIA with 11GB free space on my C drive. There was no effect when I tried increasing the size of PC virtual memory & set visual effects to best performance. Seems PC resources is being eaten up when dvbProg is running. Please advice. Thanks. h3dja
    Pakistan
    Same problem with me, but only with encrypted channels like Multivison and ,no one can solve this problem,or not help us.
    are you using a new Skystar2 rev 2.6 cause im having this problem also. i dont know why.its only in this new revision having this problem cause my friend has ss2 with olad revision does not having this problem. Its an head ache lots of bug.
    PAKISTAN
    sometime u have more then 1 decoder
    Cyberlink , WINDVD,NVIDIA etc...
    first of all check your Decoder Settings. Install and use only one decoder.
    the second main problem is that u have more then 1 DVB Player
    PROG DVB,My Theater,Dvb Dream etc...
    I am using PROGDVB only with Cyberlink Decoder.
    and i have new version of Skystar 2
    its working Smoth always with both FTA and encrypted channels
    Only use selected Softwares.. PROBDVB,Cyberlink Decoder..
    More then 1 Decoder will mess with your PC.
    If u have any problem with PROGDVB then go fo DVB Dream.
    But i Suggest u PROGDVB. its good
    Take Care
    Banned Teacher
    Pitesti ROMANIA
    Default /?
    Aug 2004
    Default SS2 freezing problem
    Quote Originally Posted by ferdz
    Im using SS2 with installation s/w Ver 4.2.10. I dont have idea if this is the new SS2.
    Well try advise on posts 221. Thanks to aqeelraza.
  1. EURO SPORT FREEZING
    By fazal sher in forum RDI - English
    Last Post: 1st June 2006, 14:37
  2. Log in problem
    Last Post: 18th November 2005, 17:12
  3. problem with ECM
    By raphex in forum Placi DVB
    Last Post: 15th November 2005, 13:51
  4. astra 19 freezing
    By mOBY2 in forum Placi DVB
    Last Post: 28th December 2004, 15:59
  5. 065 probleme de freezing la 5-10 min
    By ghettoman in forum Placi DVB
    Last Post: 25th October 2004, 18:41
