    Jan 2009
    Brasov - Romania
    Default DM800HD : Problem with local card
    Hi,
    I'm a newbie and i've a problem with my local card (Dolce)
    I've a DM800HD and i put my card in the reader.
    The channels are ok but after a time, i have black screen
    I need to put back the card on the dolce receiver to renew the card access and after i can put it back in the DM.
    I think i forgot something in my config for renewing the card access but what ?
    Thanks
    HJ
    Târnacopist Expert
    /home/satwien/
    What emu do u use? CCcam? Newcs?
    Jan 2009
    Brasov - Romania
    CCcam
    HJ
    Târnacopist Expert
    /home/satwien/
    As far I know, for dm800 the only possible solution is to read the card with newcs and then to connect the cccam server through a N: line.
    This was not tested by me but I saw this solutions working.
    Jan 2009
    Brasov - Romania
    Thanks SatWien,
    I will try that tonight
    HJ
    Jan 2009
    Brasov - Romania
    I've changed my config and installed newcs_1.60
    the CCcam and the newcs are running but it's not working with dolce
    in the telnet, i get this message
    [ Newcamd:34000 ] Can't decrypt client msg, rejecting!
    If i change my CCcam config ( i comment the N: line and reactivate the BOXKEY) it's working
    Any idea ?
    In the newcs.xml, what is the format of the boxkey tag : hexa or decimal ?
    HJ
    Jan 2009
    Brasov - Romania
    Still not working
    In my log i get :
    Code:
    [ Config ] Option <crypto-special> for device 0 (lower) not present, defaulting to NO
    [ Config ] Value in <boxkey> for device 0 (lower) is INVALID, skipping...
    [ Config ] Pincode for device 0 (lower): 0000
    [ Config ] /dev/sci0 ECM priority: round...
    in newcs.xml, my readers config is like that
    Code:
    <readers name="Card Readers">
            <device>
                <name>lower</name>
                <type>sci</type>
                <mhz>357</mhz>
                <node>/dev/sci0</node>
                <parity>odd</parity>
                <reset>normal</reset>
                <export>Yes</export>
                <enabled>Yes</enabled>
                <blocksa>Yes</blocksa>
                <blockua>No</blockua>
                <blockga>Yes</blockga>
                <boxkey>0182...854</boxkey>
                <!-- <rsa>0000000000</rsa> -->
                <!-- <''''''-camkey>0000000000000000</''''''-camkey> -->
                <!-- <''''''-camkey-data>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</''''''-camkey-data> -->
                <!-- <crypto-special>No</crypto-special> -->
                <!-- <ipk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</ipk> -->
                <!-- <ucpk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</ucpk> -->
                <PTShandshake>No</PTShandshake>
                <carddetect>yes</carddetect>
                <newcamd_port>34000</newcamd_port>
                <autosid>Yes</autosid>
                <Seca-PPV>no</Seca-PPV>
                <pincode>0000</pincode>
                <priority>round</priority>
            </device>
        </readers>
    I tried to put the <boxkey> in hexa and it's the same
    HJ
    Târnacopist Expert
    /home/satwien/
    First of all you should start only the newcs and assure that the card init is ok. I suppose that you don't follow the BK algorithm and that's the reason why your emu is not working.
    Unfortunately, Dolce is a Romanian provider and I cannot post the algorithm on this forum, but I'm sure that you will find it.
