    Default DRAGON S-1100 ... SOLUTIA IDEALA PENTRU MAX SI FOCUS!!!
    Receiverul DRAGON S-1100 are incorporat un CAM Multisistem care vede o gramada de carduri oficiale, iar chestia buna este ca si deschide canalele ... Astazi va prezint MAX si FOCUS!
    Introducand cardul MAX am obtinut urmatoarele ...
    Lista de canale la DRAGON S-1100 ...
    Iata ce se intampla cand introducem cardul FOCUS SAT ...
    Lista de canale FOCUS SAT pe DRAGON S-1100 ...
    Meniul MULTICAM ...
    Si emulatorul ...
    CAM ATAT DEOCAMDATA
    ovex
    Niste detalii tehnice am uitat sa pun
    Tuner
    - FEC Rate : 1/2, 2/3, 3/4, 5/6, 7/8
    - Input Connector : F type female(75ohm)
    - Frequency Range : 950MHz ~ 2150MHz
    - Symbol Rate : 2 ~ 45Msps
    - Demodulation : QPSK
    RF modulator
    - PLL type : CH 21 ~ 69 for the modulation
    - TV standard : PAL B/G, I, D/K NTSC M selectable
    - RF connector : 750Ohms, 169-2, Male/Female
    - Frequency Range : UHF : 470 ~ 860MHz
    MPEG TS A/V Decoder
    - Video Resolution : 720 X 576
    - Input Bit Rate : Max. 90Mbit/s
    - Transport Stream : MPEG-2 ISO/IEC 13818-1
    - Audio Decoding : MPEG/Musical Layer 1&2
    - Audio Mode : Single / Dual Channel
    A/V & Data Input/Output
    - Video RCA : CVBS
    ...........TV SCART : CVBS, RGB
    ...........VCR SCART : CVBS
    - Audio RCA/Cinch Volume & Mute Control
    ...........(Resolution : 20bits DAC, Max 2Vrms)
    ...........TV SCART (L)(R)
    - S/PDIF of Dolby Digital Bit stream Out
    System Resources
    - Flash Memory : 2Mbytes
    - SDRAM : 16Mbytes
    - Main CPU MPEG Chip : IBM Vulcan
    Power Supply
    - Input Voltage : AC 90 to 250v, 50/60Hz
    - Power Consumption : Max. 30W
    - Protection : Separate Internal Fuse
    - Type : SMPS
    Physical Specification
    - Size(W X H X D) : 340 X 60 X 250(mm)
    - Net Weight : 2.5 Kg
    - Operating Temperature : +5 C ~ +50 C
    - Storage Temperature : -20 C ~ +60 C
    Option Function
    IBM Receiver And Dragon Embedded Receiver Protect yourself when ordering or providing samples. Product Description: We provide powerful ibm receiver with 7 cas systems inside together with dragon cam embedded receiver. Currently we have established distributors network in europe, middle east and north africa. Our product have distinctive features which make us different from other products. * 7 cas funciton: Possibility of working with 7 cas systems of betacrypt, viaccess, cryptoworks, nagravision, seca, ******, conax - working with original cards of ntv+, german premiere, cyfra+, nova, canalsatellite france, canal+ nordic, upc direct, digiturk.. ) * invalid card function: Some viaccess original cards(don't panic,247 sex, sexview, hrt, art), if its validity is finished, you can use it again with our receiver.. Our product can reactivate your invalid viaccess card * datastamps function: Usually unoffical cams and receivers should be upgraded in the shop when the broadcasters updated their cas systems, but our receiver updated its cas version automatically. So, you don't have to go to shop anymore. It is easily understood that our receiver has 7 different original cams embedded. Basically, it has powerful and stable functions as below * fantastic& user friendly osd menu * very fast channel change speed * 5000 channel/100 satellite recordable * subtitle/teletext function * usals function * channel sorting by alphabet, cas, satellite, network * pip function(multi-picture) * simple zoom-in function * main cpu: Powerful ibm vulcan chip * flash:2mbytes, sdram:16 mbytes * s/pdif optical(optional) * independent emulate s/w: Cas i version of scrambled channel(tps, absat, globecast, orf, mtv.. ), au for polsat/tv cabo In the meanwhile, our x dragon(dragon embedded receiver) has dragon cam function together with the above mentioned feature. X dragon's predator s/w can be updated by dream multimedai through the internet. And x dragon's dreamcrypt cas support the original cards of inxtc and xplus tv on hotbird. The osd languages support english, german, french, spanish, arabic, persian, turkey, croatian, serbian, czech, hungarian, swedish, norwegian, russian Model No: e-1100, e-1200, e-2100, e-2200, d-2200 Other Price Terms: negotiable Origin: Korea Brand Name: OEM acceptable Quality/Safety Certifications: CE
    Vreau sa va mai spun ca, pentru a vedea cardul FOCUS este obligatoriu necesar softul v0.87 din 28 Mai 2005 ...
    PRETUL ACESTUI RECEIVER JONGLEAZA INTRE 400 - 450 RON.
    ovex
    Mar 2003
    crisana
    am si eu 2 dragoane... astept cartela focus...oare cartela max se gaseste pe undeva prin bihor-arad, ca am stat vreo jumatate de ora de vorba cu robotul de la max si degeaba, n-o vrut sa mi-l dea pe seful lui ))
    max si focus n-au si ei un miro al lor?...pacat...
    Mar 2003
    crisana
    Jan 2003
    intrebare de baraj: face AU pe Conax si VIA?
    @onyx
    In meniul MULTICAM apare ...
    EMU EMM ------------> YES / NO
    SmartCard EMM ----> YES / NO
    ... si normal ar trebui sa faca ... Poate @cableguy stie mai bine. In cryptoworks pe JETIX Romania HOTBIRD face sigur. Are un cablist de la mine.
    Trebuie sa verific la sfarsitul lunii pe FOCUS. La MAX incerc un virgin sa vad daca o ia ...
    ovex
    Dublin, Irlanda
    la sectiunea receptoare am postat si eu despre Dragon Box CI 600, preluat de pe:
    http://www.hm-sat-shop.de/10672.ahtml
    la costul de 175 euro.
    Pe scurt:
    Multi-Picture Unterstützung (4,9,10,13 oder 16 Bilder)
    DolbyDigital Ausgang (AC3)
    6000 programmierbare Kanäle
    Oscilloscope/Spectrum Analyzer Funktion
    Zoom in/out in TV Kanäle
    Audiosuche in Radio Kanälen
    Specificatii tehnice
    MPEG-2 Digital / DVB kompatibel.
    Eingangsfrequenz 950-2150Mhz
    1 Smartcard Lesegerät (FirecryptCam)
    1 CI-Modul Einschub für
    Viaccess, ******,Mediaguard,Conax
    Cryptoworks,Nagravision und mehr.
    1 LNB input[F-Type],IF Durchschleifsignal.
    6,000 Kanäle für TV & Radio
    Speicherplatz für 1000 Transponder
    Schnelle Kanalumschaltzeit.
    Einfachste Menüführung.
    Favoritenkanäle/Kindersicherung
    SCPC & MCPC Empfang von
    C/KU-Band Satelliten.
    Grafische EPG Kanalinformationen.
    Teletext Unterstützung
    Verfügbare Sprachoptionen [Englisch, Deutsch,
    Türkisch,Italenisch,Französisch, Spanisch,
    Polnisch,Tschechisch,Griechisch,Holländisch
    Russisch,PortugisischArabisch, Persisch ].
    DieseqC 1.0 und DiSEqC 1.2/1.3 Kompatibel
    Firmware RS 232 Downloading [Datentransfer
    Receiver zu Receiver und/oder PC zu Receiver
    Einfaches Bildschirm-Menüführung mit sehr
    bedienerfreundlichen Buttons vergleichbar mit
    PC Betriebssystemen.
    nu stiu daca sunt rude cu cel postat de tine insa suna bine.
  1. dragon s-1100
    By rdi in forum RDI - Satelit
    Last Post: 14th October 2006, 02:54
  2. dragon s 1100
    Last Post: 14th March 2006, 10:55
  3. DRAGON S- 1100
    By salogel in forum SD Receivers
    Last Post: 27th January 2005, 13:00
  4. Dragon S-1100
    By torpedo11 in forum SD Receivers
    Last Post: 26th January 2005, 11:05
  5. dragon S-1100
    Last Post: 5th January 1970, 09:59
