Results 1 to 10 of 10
    Aug 2007
    Default Help!Pt cunascatori
    Ajutati-ma cu o problema nasoala:Am sau am avut un reciver TeleSystem 4.4C care din cite am gasit este o clona cum zice aici
    Clones Dsr6000 (skardin)
    STI5518MVB-X FLASH=2Mb TUNER=F7VZ0194 SDRAM=8Mb EPROM=8Kb Remote:IRC83120
    Asci DSR6000
    Axas DSR 8000
    Comsat Polonia FTA 14
    Comsat Polonia CI 14
    Comsat Polonia CI 22
    Comsat Polonia CI (old)
    Comsat Polonia FTA 15
    Comsat Polonia FTA 16
    Comsat Polonia FTA 23
    Comsat Polonia FTA 31
    DSR 2000 FTA-Silverstar
    DSR 6000
    DSR 6012
    DSR 6012 M
    DSR 8000
    DSR 6000 CI
    Echostar DSB 770 FTA
    Echostar DSB 808 2CI
    Echostar DSB 780 FTA
    Echostar DSB 880
    Echostar DSB 890
    Echostar DSB 1220 FTA
    Echostar DSB 1230 FTA
    Echostar DSB 2220
    Echostar DSB 2230
    Echostar DSB 2600
    Echostar DSB 3600
    Europhon DSR 6000 FTA
    Fuba ODE-850
    Invion DVS-00201-IEU
    Koscom DSR 6000 FTA
    Maximal DSR 6000 FTA
    Microsat 6000 FTA
    Neuling Digitrac 6000
    Neusat DSR 6000 FTA
    Optex ORD-9510
    Palcom DSL-2200 CI
    Palcom DSL4S
    Rebox RE 2250MG
    Sat+ S3.1
    Sat+ X9.1 Freeview
    Seg DSR6012
    Skardin SD2002
    Skymaster DCI 9410
    Skymaster DS 4000 CI
    Skymaster DS 4050 CI
    Skymaster DS 44
    Skymaster DS 55
    Skymaster DX 22
    Skymaster DX 23 eigene modelle
    Skymaster DX 24 eigene modelle
    Skymaster DXL 9400
    Skymaster DXM 9420
    Skyplus DSR 2000 FTA-Silverstar
    Skyplus DSR 4000 CI
    Skyplus DSR 4000 FTA
    Skyplus DSR 6000
    Skyplus DSR 6000 CI
    Skyplus DSR 6012
    Skyplus DSR 6012M
    Skyplus DSR 8000
    Strong SRT 6125
    Strong SRT 6126
    Strong SRT 6130
    Strong SRT 6155
    Strong SRT 6158
    Strong SRT 6160
    Strong SRT 6355
    Strong SRT 6850
    Strong SRT 6855
    Telesystem TS 4.0F
    Telesystem TS 4.4C
    Tevion FTA 203
    ma maninca undeva si ai pun astea: PatchLoader [5-II].zip ( http://upl.frocusa.net/index.php?lng=en&get_id=76 ) care defapt e Weaksoft 1.6.0. Cu Weaksof 1.8.0 dadea cu virgula
    1. Soft: SRT61xx_2p6_24062006.urt ( http://upl.frocusa.net/index.php?lng=en&get_id=442 ) cu Aplication Loader din http://upl.frocusa.net/index.php?lng=en&get_id=493
    2. Patch: patch_ver_1.0_11-11-2007_MCM.bin ( http://upl.frocusa.net/index.php?lng=en&get_id=1665 ) cu Weaksoft 1.6.0
    3: AKeys la zii ( http://upl.frocusa.net/index.php?lng=en&p=4 )
    Totul s-a instalat frumos dau pe Thor... NU MAI AM SEMNAL DE LA ANTENA.Cineva zicea ca nu am modulatorul Sharp sau asa ceva si daia nu am semnal. Va rog un sfat e binevenit.Mess:iulian_st
    Apr 2006
    trebuie sa schimbi tunerul cu unul sharp ,daca vrei iti pot da eu ,detali in pm
    Tunnerul nu este Sharp ! este o buba cunoscuta ! schimba-l sau revino la fw original !
    Aug 2007
    Quote Originally Posted by gobi2000 View Post
    esti sigur ca ai sti5518 pe el?
    Fara suparare. Ce e aia sti5518? Daca se poate niste explicatii!
    Eu am citit undeva ca modelele astea vin in doua variante : cu tuner Zarlink si cu tuner Sharp ;Daca este Sharp e OK se poate pune soft de Strong 61x5 , daca este Zarlink - nu . Al meu e cu Zarlink deci logic ar fi sa ai pun Sharp. Pareri?
    Apr 2006
    Quote Originally Posted by ullisse View Post
    se refera la procesor.........
    Mar 2009
    romania
    ce soft merge sa pun pe un universum fta DSR451 sau ceva care sa ma poata ajuta si vreau sa-l folosesc in gigi
    Apr 2009
    Default kaon 100 sco
    Salut! Am si eu un Ksf 100 sco.L-am luat gata facut si a mers pana la prima schimbare de key.L-am dus la doctor ,de 2 ori chiar si aceeasi problema . Nu mai intra in meniu key din galben-meniu.Modelul este s/w v 03.00.00 h/w vff.oc.ff v 6.1.9.Ce trebuie sa-i fac?Prin cablu se leaga cu calculatorul dar nu stiu exact ce are nevoie .Ce b.load ii trebe si ce soft.Dati-mi si mie o idee inainte de a-l face praf pe dibuite!
    Jan 2010
    BUCURESTI
    Default Schimbarea tunerului zarlink cu unul sharp
    Quote Originally Posted by mesteru222 View Post
    Buna ziua ! Am nevoie de sfatul dumneavuastra ! La un Palcom(clona SRT 6125) am schimbat softul dar trebuie sa schimb tunerul zarlink.Am scos un tuner sharp de la un tevion dfa 202 dar nu are numerotarea pinilor pe placuta adaptor care are mufe mama( 32 ).Pe placa Palcomului care are tot mufe mama sunt 28 adica -4 ale RCA care sunt fixe pe placa si sunt toate pe aceiasi linie, dar ale sarpului sunt dispusi pe 2 liniide cate 16.Aveti o schema ,sau numerotarea pinilor?( ID :marin1949)sau aici
    Mar 2010
    Los Angeles Website Design
    large format printing
    Nepriceput in multe Expert
    Feb 2006
    SIBIU
    aici ai ce vrei
    cu null modem
    prima data se pune boot-ul ala mai mare 800 de kb
    apoi cu loaderul se pune softul mai nou , apesi tasta space de pe tastatura si alegi fisierul cu softul
    dupa ce pui keyle trebuie sa intri in menu sa activezi emulatorul la canale criptate sau cam asa ceva, altfel nu vezi nimic
