Results 1 to 6 of 6
Thread: Help dreambox
    Jul 2008
    Default Help dreambox
    I have reciver dreambox 500+ i have dsl its working in my computer but when i take the cable and put into the receiver its give ip:10.1.1.9 and its not working .after i take the receiver replace another place its working and then i get ip:192.168.1.66
    so i told the operator he told me i have dsl problem i must be need configured manually so help please.
    This is my computer configaration:
    Ip address:10.1.1.50
    subnetmask:255.255.255.0
    default gateway:10.1.1.40
    dns:212.71.32.19
    212.71.32.20
    Oct 2008
    Quote Originally Posted by imranahmed View Post
    dns:212.71.32.19
    212.71.32.20
    go to dreambox menu>>setup>>expert setup>>commuinication setup. check the DHCP box and click green button. this wil get your dream ip automatically. when you are done, uncheck DHCP box and click green button again.
    hoppe this solve your problem.
    sometimes, it depends on the router giving you a bad gateway (like speedtouch routers). so he should manually set his IP, and gateway like what is displayed in his computer.
    IP 10.1.1.51
    subnet 255.255.255.0
    gateway 10.1.1.40
    dns 10.1.1.40 or 212.71.32.19/20
    Jul 2008
    Default Thanks
    Thank u boss
    i assume then that it is working?
    Africa-Kenya-Nbi
    and if it is working dont forget to uncheck the
    DHCP box on communication set up
