    Default Help about Hercule PCI DVB card
    Dear,
    Can someone help me to have TPS with my Hercule DVB card placed on my PC.
    Wich files I need, where to copy them.
    Thanks you
    try installing progdvb (if you still don't have it) then get s2emu and softcam.key from the mach1 file section of this forum. you put them in the plugins folder. good luck.
    Dear,
    Thks for your reply
    I have installed Progdvb but this program haven't hercule card device (I have seen Skystar 1 & 2, pinnacle, etc. but not Hercule). Can someone tell me where to find hercule device file or another programme which is Hercule dvb card copatible.
    May 2004
    You can dry Twinhan drivers with your hercules card or try Teleman SkyMedia and Haupauge DEC card drivers for your card. some may work
    wish you good luck.
    For Hercules DVB PCI card select TwinHan in ProgDVB then register thsource.ax but from an older version of progdvb (thsource.ax -> right click -> properties -> Version -> File Version: 2.5 )
  1. Replies: 4
    Last Post: 11th January 2011, 22:18
  2. Replies: 5
    Last Post: 4th August 2006, 07:53
  3. NOUL CARD:ATTACK CARD care promite mult
    By rusudanion in forum RDI - Satelit
    Last Post: 20th July 2006, 09:39
  4. Smart-card,softcam,cam(ci),card ubc
    By tapta in forum RDI - English
    Last Post: 22nd September 2005, 09:21
