Results 1 to 3 of 3
    Oct 2008
    Default Help me pls, omega St 5118 alb (5119?) BFL / BFR pins ?
    Dear gurus of this fabulous forum (Mr. Yan Naing, Mr. Cougil and others) I'm wasn't able to find on internet the correct pin for the BfL and BfR signals of Telestar SRS 1 FTA receiver CPU that's a Omega St x 5118 alb (I think 5119 compatible).
    Anyone can tell me pls what pin I have to put to GND or by 1k resistor in order to boot the 5118 CPU not from Ram/Rom but from Link?
    I used Wall 2.2 and jKeys 2.11 with 'Kaon 5518 2MB' definitions because the Telestar SRS 1 receiver contain a SST m29w160et Flash and a A2V28S40CTP Ram but always in WinXP I receive the FFFFFFFF/FFFFFFFF (Jedec) unknown flash type error with jKeys. I'm actually able to read and erase the flash, but I can't write never.
    Thanks in advance for replies, any helps will be helpfull!
    Oct 2008
    Pls help me almost providing datasheet of St 5118 to understand what are the BfL BfR pins, Tnx!
    Oct 2008
    Default for Mr. Yan Naing & Mr. Cogil, pls!
    I found the 5105 216pin datasheet and seem to be pin compatible with mine 5118 alb, is this true Mr. Yan Naing / Mr. Cogil ?
