Results 1 to 10 of 10
    Default Technosat Bodyguard 555 Help
    can somebody point me to the procedure of updating this box? i have the software, also the loader, but when i try to upload the software, the loader says there is something wrong with the memory address or something. which do i click, OTA, etc? thanks in advance for the help.
    Jul 2005
    Default Re: Technosat Bodyguard 555 Help
    I have the same box. I just followed the given instructions succesfully. Click "Execution" as download mode not "OTA".
    May 2004
    Kuwait
    Instructions to upgrade your Digital Satellite Receiver
    1. Turn off STB
    2. Connect the serial cable between the PC and STB
    3. Select COM port
    4. Choose the file to be downloaded
    5. Select Download Mode
    6. Start Downlaod
    7. Turn on STB
    8. Wait until download complete
    It should work with this way boknoy otherwise check ur STB link or Wire to upgrade..
    take care.
    ok, thanks for the input. i'll try it out day after tomorrow if this step works.
    Quote Originally Posted by lovebird
    1. Turn off STB
    3. Select COM port
    6. Start Downlaod
    7. Turn on STB
    take care.
    dear love bird ,how we can add new provider id in this box?
    and also, is there a way to manually edit the key codes? all i can see is always off, on, off. no manual edit.
    Jul 2005
    Choose "always off".
    To edit the key code, press "?" on ur RCU.
    there we go, thanks jimiski.
    still no go. i did it via "execution" and i got an error something like memory and sdram number mismatch.
    Jul 2005
    Got no problem upgrading my box..try a fresh download..use a different pc perhaps. I was using an older pc running windows 98.
  1. Technosat bodyguard 555 help
    By usman2r in forum RDI - English
    Last Post: 6th June 2006, 03:19
  2. about technosat bodyguard 555
    By scrombi in forum RDI - English
    Last Post: 21st April 2006, 18:38
  3. About Technosat bodyguard 555
    Last Post: 20th April 2006, 19:01
  4. About Technosat bodyguard 555
    Last Post: 17th January 2006, 22:22
  5. Help... (Technosat Bodyguard 555)
    By leo100275 in forum RDI - English
    Last Post: 4th June 2005, 14:44
