Results 1 to 11 of 11
    Oct 2008
    Default Sat receiver for HD and CS ?
    Hello all,
    I am looking to buy a sat receiver that can do HD and also CS, i would like to have your opinion on which models are good now.
    Also if I do CS with toher people does everybvody have to have the same type of receiver or as long as each receiver does CS it should be possible to connect and do CS (for example 1 dreambox and 1 other receiver)
    Thanks a lot
    as long as the protocols are the same, there should be no problem with it.
    dm800 or darkboxhd9000
    Aug 2007
    Default Cheap and Best Cardsharing Receiver
    Please advise any cheap and best card sharing receiver. Indicate price, where to buy.
    would you like me to give you the money too?
    don't be lazy..... SEARCH!
    Aug 2007
    Thank u for your fast response. I will search
    Oct 2008
    Ok, thanks a lot.
    So in theory if i find the same CS software I could do CS between a dm800s and a DM500 or 600, correct ?
    Quote Originally Posted by raoulseca View Post
    Ok, thanks a lot.
    you are correct.
    Oct 2008
    you are correct.
    Ok, thanks for the tips, i'm getting a DM800S.
    Apparently there are 2 CS solutions which are gbox and cccam, is there a CLEAR (for noobs) tutorial to explain which does what and so on ?
    Thanks again
    gbox is old, cccam is currently the easiest to configure.
    Aug 2008
    HI
    and between dm800 and IPbox 9000, the best is ...?
    gbox and cccam works for dm800 and ipbox 9000 ?
    thanks
    fte s300 + gbox 2.21
    lnb twin
    Oct 2008
    Ok, getting cccam and starting to have fun with it...
    Thanks for the infos
