    Default Mediastar Hi Tech help agn
    hi,
    I am trying to clone a mediastar hi tech to another mediastar hitech. Gives me an error of "version mismatch".
    Will somebody help me hw I can make both rcvr versions the same?
    master rcvr:
    main version : 1.62 G6C5M1S2
    boot version : 1.30
    data version : 21
    last updated : 2005/7/11
    slave rcvr:
    main version: 1.49 G6C3M1S3
    boot version : 1.25
    data version : 0X8
    last update : 2004/5/10
    P L E A S E
    roger26
    hope secretman007 & aslmx will see this sos.
    Sep 2004
    UAE
    hi m8,
    version mismatch means not having the same firmware, why dont u try pc to stb download the one with old firmware dated 2004/5/10
    and remember, there r 2 types of hitech, 1 is hitech and the other 1 is hitech-s, maybe from that point u can have it updated
    Default ty aslmx
    hi aslmx,
    tks for replying,
    can u kindly tell me where I can get and download the firmware?
    Pls extend ur patient, dis is the first time i will try pc to stb programming.
    tks,
    roger26
    Sep 2004
    UAE
    hi roger,
    download the firmware here
    experiment which file is suitable for ur old receiver, try hitec-11jul2005.zip or hitec-s-11jul2005.zip
    Default thank you
    hi aslmx,
    GOT IT
    Thanks for your instructions. Experimented with the two files, and found the correct file for my stb. Now i learned another important thing because of your guidance.
    thank you very much! Appreciate it much!
    tks aslmx and also to you secretman007.
    roger26
  1. mediastar Hi Tech
    By roger26 in forum RDI - English
    Last Post: 11th January 2006, 06:46
  2. Mediastar Hi Tech
    Last Post: 2nd December 2005, 11:32
  3. Mediastar Hi Tech
    Last Post: 19th September 2005, 09:48
  4. Mediastar Hi Tech
    Last Post: 18th September 2005, 10:18
  5. Mediastar Hi Tech
    Last Post: 4th September 2005, 08:19
