Results 1 to 3 of 3
    Feb 2008
    Default DM 500+ Help - LNBSetup
    Hello All,
    Just bought a DM500+.
    My landlord provides the following:-
    (from my previous STB, the details are as follows)
    nilesat:
    lnb type: single
    Freq: 10700
    Diseq: 2
    22Khz: off
    12V: on
    arabsat:
    lnb type: single
    freq: 9750
    diseq: 1
    22Khz: off
    12V: on
    DM500+ has Enigma 1.4.0 image. I have tried so many combinations. Still could not get any signal from dish. (from the above setting, my old stb works fine. at present, i just wanna get fta channel only)
    Tried user defined options for diseq settings.
    DM experts, any tips to go about?
    Thank you
    Jun 2007
    in dm GO TO LNB FREQUENCY LOW IS 9750 AND HIGH IS 10600 REST IS DEFAULT THATS ALL THEN PRESS BLUE BUTTON TO GO TO NEXT PAGE THERE SELECT THE DISEQC 1.0,1.1,1.2 ETC BASED ON THE VERSION OF UR DISEQC SELECT THEN SELECT THE PORT AA = 1 ,AB =2 THATS ALL THEN DO AUTO SEARCH
    Feb 2008
    Thank you
    First phase is over
