    Sep 2008
    Default ali 3329 c problem
    hi; all friend i have echolink 700fta super ; i software it when i connected it tv ; and on stb; only written stb ;;ON;; and not run or statrt and i again download it but when i put the file in loader and click next an shows that;;;;Target not connect OR target is error status;;what solution of this problem. and how i solved it any body tell me .i m wating ur reply thanks all. by;;;;;;;;
    Sep 2008
    Default same problem
    hi Bakhtillah the same problem is with me but i also dont no the solution why this problem is occuring do any one know the solution plzzzzzzzzzzzzz help out quick
    Pakistan
    Yes i have found another way to solve this ON problem that sometimes come after software upgrading.and its solution is again upgrading.Follow simple instruction connect your receiver to another but same kind of receiver.
    0:Connect them with the help of cable
    1:switch off the receiver with ON problem.or unplug its power Cable
    2:Put the other receiver on stand by i mean power it off from remote button
    3:Now press 369 this will activate software upgrading and the indicator will start blinking in the front panel of receiver
    4:Now power on the receiver with ON problem
    There U go now the receiver is upgrading wait until the receiver shows 100 and then END.I hope ur problem will be solved.
    I am not joking this procedure is 100 percent accurate and checked and confirmed by me.
    not check my self............
    i will wait for your best suggestion
    Sep 2008
    Default ya good idea
    ya i think its a god idea but we should try some other solution so any knows any other solution so plz help out quick by this solution we need to have two receivers and that of same kind
    so think try something else
