Results 1 to 9 of 9
    Feb 2007
    Negombo, Sri Lanka
    Default Dialog TV going MPEG 4
    DM 600+80GB DM 7020+160GB+ LED 55"
    Jun 2007
    Dont worry use MPEG4 cards S2 cards and enjoy
    Feb 2007
    Negombo, Sri Lanka
    I mean what will happen to cardsharing clients-wont they be affected if the CS supplier does not fall in line ?
    Jul 2008
    As we had thrown our Analog STB.
    after some times we have to do same with our MPEG-2 STB.
    www.realinfo.tv All Info that you Need.
    Dec 2007
    Russia
    Default Solution is SS HD 2 Cards
    Quote Originally Posted by felicianf View Post
    They are replacing only the decoder, not the '''''' card, thus we may continue the cardsharing with SS HD 2 dvb-sII cards. its only 120$, you dont need to spend more as DM 800, so dont worry.
    I Love Linux => Fedora 9
    go Fedora go
    <script type="text/javascript" src="http://www.ubuntu.com/files/countdown/display2.js"></script>
    Jun 2009
    Smile DialogTV
    Hi,
    I would like to know whether DialogTV in Sri Lanka could be hacked..
    Normally the Decoder (STB) is Technosat CDVB5110D (Coship) and they have married each smartcard to its receiver. Therefore one Card will not work in another decoder.
    As far as I know, they use IRDETO2 encryption.
    I believe that some genius could crack it.
    Have anyone of you tried it?
    I have heard that the decoder firmware can be altered by jTagging.
    If you got any clue, Pls mail me at [email protected]
    Thanks in advance.
    Dec 2007
    INDIA
    Cool Dialog TV
    Leave it. Never going to happen. It's not an easy task. No one will try to it otherwise they will get some benefit. Finding key is never easy wether it's Nagra or NDS.
    Chennai, India
    Talking
    I2E is hard to crack
    Apr 2009
    Default Dialog
    Quote Originally Posted by arunasomaweera View Post
    Hi,
    Thanks in advance.
    Dont waste your time, better use card sharing
