Thread: t888 help
    Jul 2008
    Default t888 help
    i have t888 here in the phil.. i reset my box by codes and the procedure i found here... successfully it works, and i used this for almost 5days since july, after that i didn't used this for 2 days..until now it always in scramble channel..
    can you pls give me some advice, or suggestion regards this problem..
    thanks in advance....
    slapshock
    waxxx
    Dec 2007
    Iligan City
    Maybe your box is not AU,what kind of your card?
    Dec 2006
    Quote Originally Posted by slapshock View Post
    bro,your t-888 is 1mb or t-888(plus)2mb or t-888 silver?at the moment there is no au software for the said models but sometimes it rolls automatically.if you are using t-888 2mb,pls upgrade to the latest patch dated 18.06.08(ver.date) 21.06.08 date of release from www.dsrsoftwares.net/ while for t-888 1mb the latest is 16may 08.for t-888 silver pls download the latest patch from the abovementioned site.clear all the old cheannels and rescan.thanks and goodluck.
    Jul 2008
    Quote Originally Posted by ferdie444 View Post
    sir my t888 is 2mbplus.. ok sir thank you so much. i will try this software.. thanks
    slapshock
    waxxx
    Dec 2006
    You're welcome slapshock.....
