    Apr 2006
    DUBAI
    Default Problem, I am not able to solve
    I am using PCI - SHINESTAR HS-DTV Hs-1020 (Red) card and using four dish antennas (Hotbird; Nilesat; Insat 4B and Insat2e,3b (C-Band)). For nearly two years it went good; but now I am facing strang problem that I am not able to solve;
    While all the four dishes connected, Insat 4B only I am getting; If I disconnect Insat 4B, nothing I am getting; If I diconnect Insat 4B and Insat 2E3b, I am getting Hotbird and nilesat in good;
    I changed diseqc switch but the same problem is there; Which version diseqc I have to use?
    Thank you
    well... that's strange. ordinary 4in-1out disecqs should work.
    Africa-Kenya-Nbi
    What about your diseqc switch settings on the decoder are they
    correct as was before.
    Do the set up again while putting them in one at a go.
    Apr 2006
    DUBAI
    I found LNB of Hotbird is fault and I changed the LNB. Now I am getting good quality of signal. Now I have to check the others.
    Thank you
