Results 1 to 14 of 14
    Jul 2005
    Default help for opentel
    Need help for opentel ods 2000civ
    Lahore
    Default Re: help for opentel
    Quote Originally Posted by manny_8998
    which kind of help do you need?
    If you are interested to upgrade your STB with key code EMU s/w?
    Fte Max 100S
    Humax IRCI-5400z
    Jul 2005
    Yes Masood, pls help me to upgrade my stb with key code EMU s/w, thanks for responding
    Jul 2005
    pls help me to upgrade my stb and what website can i go to upgrade it
    Lahore
    Only ODS-3000 CI and FTA are having facility to upgrade with key code menu EMU s/w
    Fte Max 100S
    Humax IRCI-5400z
    Jul 2005
    so what will i do to upgrade it to watch encrypted channels like m vision, pls help
    manny_8998
    the solutiion is either by another receiver which has the facility of entering keys ......... or buy an appropriate cam that can be used with Opentel .............
    masood jee will tell u abt the Cam u should use .....
    bye
    Lahore
    Quote Originally Posted by superia4u
    bye
    @superia
    the model is already built in with viaccess CAM,,,he needs to insert a Fun card ,programmed with latest Mach1 files
    Fte Max 100S
    Humax IRCI-5400z
    ok thanks for answer ............
    well i have opentel ods 2000ci
    and he has opentel ods 2000civ
    are these two different models ........ what is the difference b/w the prices of both ......................................
    Lahore
    ODS-2000 CIV is not available in Pakistan so I don't know its price.
    Your signal problem is sloved?
    Fte Max 100S
    Humax IRCI-5400z
    no no no .......
    not yet ........
    i have to on 2 digital receivers simultaneously and only then i can watch all the channels .......... otherwise problem ... problem problem
    bye
    Lahore
    i have to on 2 digital receivers simultaneously and only then i can watch all the channels .......... otherwise problem ... problem problem bye
    May I know the reason of using two STBs together?
    Fte Max 100S
    Humax IRCI-5400z
    well one receiver i use and other my relative use who is in different house ....... actually i had to buy quad lnb when i bought my second receiver i.e , neosat 9800 ci
    now sometimes i use 3 Receivers at a time ( but not always )
    i use two receivers usually ......... when my relative is at home ( but when he is not at home even then i have to keep his receiver on )
    that is the reason of using 2 receivers together ................. these are not connected together through a loop ........ all the three receivers have seperate cables from that quad lnb
    bye
    Lahore
    I see ,,,,it means you are good "khudaee khidmatgaar"(helper)
    Fte Max 100S
    Humax IRCI-5400z
  1. Opentel
    By vicjac in forum RDI - Satelit
    Last Post: 24th November 2006, 21:57
  2. Opentel
    By [email protected] in forum RDI - Satelit
    Last Post: 30th October 2006, 06:29
  3. Need Help 4 Opentel 2000CI
    By Alone_Moody in forum RDI - English
    Last Post: 19th April 2006, 19:36
  4. Opentel
    By frank087234 in forum RDI - English
    Last Post: 7th August 2005, 17:38
