Results 1 to 15 of 15
    Jan 2008
    Default dm500s problem with card reading
    i insert astro gold card into my dreambox dm500s but nothing happen. The channels seems to be blank with high signal and quality. Is it i need to do settings if use card to watch on dreambox or its autoread from card?
    installed cccam?
    ma lai xi ya
    Default astro card on dm
    installed ccam2.0.9 and new cs 1.60 ... then restart ... sure picture will appear
    Jan 2008
    Quote Originally Posted by melayu_harun View Post
    ohhh i din install anything. the cs1.60 aso download from gemini website?
    after that need do any configuration?
    Mar 2003
    98.98 East 18.56 north
    Quote Originally Posted by guess View Post
    i think so lol
    set on Newcs xml file find it on var/tuxbox/config: user pass and port also overlooking the Card
    and on CCcam cfg set 1 N-Line
    N: 127.0.0.1 Port user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 0
    Daeng
    10FT Dish 169° east-49°east
    Jan 2008
    the original nd$ gold card might have been paired with your decoder,
    you need to get your decoder serial number as well refer to this
    http://forum.paytv.ro/showthread.php...ht=tata&page=2
    Mar 2003
    Quote Originally Posted by sawasdee View Post
    you are wrong
    Astro Cards NDS works without Boxkeys about the most Receiver dont have it
    its the old Seca Receiver only updatet the Software from the Receiver
    about this Astro Channels also have same Pixeling ore frezzer all 10 seconds on Dreamboxes many Server fixed this with 2-3 Cards on Server
    Daeng
    Jan 2008
    Quote Originally Posted by Daeng View Post
    you are wrong
    after i install cccam 2.09 everthing work fine. mine is original astro gold card
    good, now play with the settings and start sharing.
    Jan 2008
    can any1 teach me how 2 do the sharing? need some ppl to help me to test also coz i just having 1 dm500s
    www.cardsharing.biz should give you some starting point.
    88dBuV
    Default Gold card stopped working
    Received my Astro goldcard two weeks ago, was working fine but now it stopped working in the DM500 with CCcam 2.09.
    have it reactivated again.
    88dBuV
    My smartcard supplier tells me that I need an original Astro receiver for reactivating the card.
    First he told me that the card didn't work at all in a DM500, I suggested to use CCcam.
    Before I had the same problems with the Seca card, it worked for months without a problem and in the last two months I had to reactivate it in a original receiver.
    Does anyone else have problems with the goldcard in a DM500?
    21.95° N 97.06° E
    i think so lol
    Dear Sir Daeng , can SUN 4 Card will work in Dreambox ?
    Thx.
    " 李俊明 Born To Help People "
