Results 1 to 11 of 11
    Jun 2007
    Default Transponder problem
    When I go through Dish TV channels on my Dreambox DM600 PVR, Some transponders not lock. But when I see a channel list preview, the EPG of every channel is visible.
    When I goto that channel the signal not lock.
    EPG loading menas the receiver getting a signal. But why it is not locked
    I have try re align the dish, changing LNB but no use. I get signal only from some transponders. The LNB settings are correct (9750 , 10600, 11700).
    What can be the problem?
    As far as I can see, the channels with higher SR (SR = 40700) is not opening.
    canine consultant Expert
    You've answered your own question, Many receivers are configured to allow an S/R rate between 2 and 40.000. and this is why your not able to access some channels with a higher S/R
    regards from OZ bassett
    Jun 2007
    No bassett
    I have 4 dishes connected to the receiver. Only Dish TV (NSS6) giving this problem. With other satellites no problem with 40700 SR.
    Any idea?
    Jun 2007
    I have even tried with FEC set to AUTO. But it not work.
    Jun 2007
    Still no luck with the Transponders
    Apr 2007
    Quote Originally Posted by dimu1234 View Post
    No bassett
    Any idea?
    Looks like an alignment problem to me.. 'Cause even though the dish is misaligned you may still be able to catch the EPG, since its just data. You need to realign your dish.
    Please let us know which TP's you are able to recieve. My guess is that you are able to recieve the 11XXX series transponders and not 12,XXX ones. Sure its a misalignment. If so.
    Sky is an Experimental Lab In the World Of Satellites.
    ::\Dish TV India::90Cms MCBS Dish Hooked to ABS-1 and Edusat and May be Insat 4CR in the Near Future::
    Jun 2007
    I can receive
    11172 H SR 27500 FEC 3/4
    12647 H SR 27500 FEC 3/4
    12688 H SR 27500 FEC 3/4
    12688 V SR 27500 FEC 3/4
    12729 V SR 27500 FEC 2/3
    I don't get
    11037 H SR 40700 FEC 2/3
    12535 V SR 40700 FEC 2/3
    12595 H SR 40700 FEC 3/4
    12595 V SR 40700 FEC 3/4
    I suggest you read the spec's of your receivers, as I said most receivers are configered to only read an S/R figure of between 2 and 40.000.
    Most europien satellites only use an S/R of 30.000.
    Question does anyone know of a satellite receiver that can handle an S/R of more then 40.000.
    And more importantly which brand of satellite receiver does Dish TV supply to it's subscribers
    As for the FEC figure, 99 per sent of receivers have this handled automaticly
    Apr 2007
    I use a beetel reciever. (www.beetel.net/set-top-boxs.htm) These handle S/R above 40 K( i think, Cause i am able to tune to these TPs), it can also read low SR signals, like the ones found on Edusat(Eg: SR- 1700).
    Dish TV uses Zenega and Kaon recievers, which can handle High S/Rs
    Jun 2007
    Well Dreambox DM600 PVR can handle SR's above 40000. I'm getting signal from other sat's of TP's above 40000 SR. This problem I get only with NSS6 satellite which broadcard Dish TV.
    Africa-Kenya-Nbi
    Set the same transponders for a signal level of above 68db on quality and try again.
    Use a satellite meter for fine tune if you have one, mostly using the poor transponders.
    also try out with any simple sat receiver just to prove its a dm problem.
