Results 1 to 2 of 2
    Jul 2008
    Default STI 5516SWC JTAG help
    I have an ADB 3000 ( telestraclear) That I need to JTAG to try and get the IRD/BK . There is a 20 pin connector. The jTAG pins are 2,4,6,16 and 18 + ground. I have taken off the BGA and found that the pins connect to :-
    R23
    R3
    P1
    AF6 ( I think)
    AE6 ( I think).
    TRST is on PIN 4 on the JTAG connector.
    Can anyone help in naming the CPU pins, i.e. is R23 TDO? etc.
    Do I need to ground one of the processor pins to enable JTAG to connect so I can read memory.?
    I'm not convinced that the CPU pins are correct, because usually the JTAG pins are all together/side by side, ....But I buzzed out the connections from the JTAG connector pins to all the pins on the BGA...and that's what I got.
    Aug 2007
    RANGOON
    Exclamation
    Join Mr.yan naing.He is one of the expert in this field.
    Stop Using Plastic Bags!
    Using 5R to Protect Our Green Planet
    Reduce,Reuse,Recycle,Reject & Return
